HID Fog Lights Installation
Hi,
I'm trying to install HID kit that i got from one of our vendors on here. The kit has two grounds and two hot legs that i need to hook up to the battery. I can do it on the passenger side as the battery is sat on that side but how do i run the wire from the driver side to the battery? Also the two grounds can be any ground on the car correct?
Thanks,
Thanks,
Well you will have to run a harness with a relay and or fuse to the hid kits. I recommend using relays so you don't drain your battery or cause a fire if there is an issue. The grounds can put anywhere to the body of the car.
sphereman
SC- 1st Gen (1992-2000)
10-10-02 04:44 AM
