New wheels (20" Vossen) rubbing when cutting the wheel in reverse
Old 04-08-14, 05:52 PM
GS357
GS357's Avatar
Default New wheels (20" Vossen) rubbing when cutting the wheel in reverse
Just put on some 20" x 9" Vossen VVS085 with Toyos 245/35/20 and the ride nice except when I cut the wheel while reversing it rubs on the plastic in the wheel well. I Want to drop it but this is making me think twice. Any ideas on what I can do to stop the rubbing aside from getting new tires.
Glad I can post my pics now!
Attached Thumbnails New wheels (20" Vossen) rubbing when cutting the wheel in reverse-imag0121.jpg   New wheels (20" Vossen) rubbing when cutting the wheel in reverse-imag0122.jpg   New wheels (20" Vossen) rubbing when cutting the wheel in reverse-imag0125.jpg   New wheels (20" Vossen) rubbing when cutting the wheel in reverse-imag0123.jpg
Old 04-08-14, 06:25 PM
avs20
avs20's Avatar
You are rubbing the fender liner that is on the cabin side of the fender. If you turn 3/4 to full lock you should be able to see where it is hitting. You can try using a heat gun to bend the liner out of the way where it is making contact, but I was unsuccessful when trying this. I ended up buying 245/30's, and now have the 245/35's sitting in the garage. Good luck!
Old 04-08-14, 07:05 PM
SLOW4DR
SLOW4DR's Avatar
pretty much, I have a 225/35 on my fronts and I rub a little on the fender liner. Will downsize whenever I kill the tire.
Old 04-08-14, 10:52 PM
Damnnchi
Damnnchi's Avatar
I just turn up the music
Old 04-09-14, 03:46 AM
IXI187IXI
IXI187IXI's Avatar
245/35 is your issue
Old 04-09-14, 12:21 PM
Dirteeboy
Dirteeboy's Avatar
I agree go with the 225/35/20. I don't rub at all when turning and my car is slammed. The only time I rub is when going over good size bumps while rolling; again my car is super low and you should be fine at that height
Old 04-09-14, 11:41 PM
3gsJaayyyy
3gsJaayyyy's Avatar
I agree with this comment as well. I ran a 225/35 on a 9.5.
Old 04-09-14, 11:46 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
looking good.... I agree..go with a 225 35.. member clos430 just put that size on his Vossens and no more rubbing.. You have have to cut out some of the fender liner...
Old 04-10-14, 04:42 AM
Diesel350
Diesel350's Avatar
Need to go with a 30 in the front next time.
Old 04-10-14, 07:21 PM
GS357
GS357's Avatar
I'm going to go with turning up the music until I need to replace the tires. Thanks tho.
Old 04-10-14, 08:02 PM
Schmexus
Schmexus's Avatar
I'm running 245/35 in the front with very little rubbing after heating the liner and pushing it where I wanted.
Old 04-11-14, 11:46 AM
GS357
GS357's Avatar
I'm going to give that a try... Can you give me a step by step on how you heated it and made the adjustments.
redb202
04-10-13 12:04 AM
anonymous1
06-10-11 06:20 AM
isthrizzy
05-17-10 05:41 PM
jackyl13
02-26-10 12:37 PM
Quick Reply: New wheels (20" Vossen) rubbing when cutting the wheel in reverse
