Active headlight auto-leveling not working
Old 03-11-14, 01:22 AM
LADavidGS
LADavidGS's Avatar
I had the same problem with my gs where the AFS light was blinking. Short story, took it to the dealership and they wanted $850 to replace the problem. I guess you have to pay to play with Lexus.
Old 03-22-14, 11:05 AM
projectsle
projectsle's Avatar
I've been having the same problem on and off for the past few months. Usually it will calibrate/auto level correctly the following night I noticed it, but now it's been 3 days straight and the issue has still be occurring. The AFS light is not on.
How did you guys narrow it down if it was a motor problem or simply just recalibration fix?
Old 03-26-14, 11:42 PM
projectsle
projectsle's Avatar
Okay, so it's clear that my driver side auto level is not working (stuck at the lowest position). Does anyone know if I manually adjust the level that it would work? Thanks in advance.
Old 03-30-14, 10:40 PM
EyeKutr
EyeKutr's Avatar
That is exactly what mine did, I adjusted to my liking and it has stayed there. It does not autolevel when the car starts. Right side does.
Old 07-28-15, 05:03 AM
andrecito
andrecito's Avatar
Did you ever figure out a fix for this problem. My driver side headlight just stopped leveling and is pointing down with no lights on my dash.
Old 07-28-15, 10:21 AM
LADavidGS
LADavidGS's Avatar
I had the the same issue with my AFS and thankfully the dealership fixed it under warranty. I believe the bill was $1500 for replace the driver side assembly.
Old 07-28-15, 06:28 PM
xbladex00
xbladex00's Avatar
Interesting.... Idk if mines works or not. I tried adjusting my headlights a couple of nights ago because the left one looks out of adjustment. I used a 8in #2 screw and it was touching the gear perfect and moving. but notihng was going left,right,up, or down.....
gocar
IS - 1st Gen (2001-2005)
11-25-13 10:57 AM
buggs384
11-10-07 07:41 AM
JuniorJr
Hybrid Technology
12-04-06 07:08 AM
bishop977
Lighting
04-13-04 02:39 AM
Quick Reply: Active headlight auto-leveling not working
