Has any of you guys expereinced your wood fading on the top your steering wheel. If so, what have you done to correct it. I hae an 06 and I'm sure the sun has ruined it. I've searched the threads and I can't seem to find a solution.
Same problem here, if you find a cheap solution aside from replacing steering wheel let me know.
There you go cheap solution
http://www.ebay.com/itm/09-LEXUS-GS350-STEERING-WHEEL-/390550043077?pt=Motors_Car_Truck_Parts_Accessories&hash=item5aee98b9c5&vxp=mtr
Btw I always put paint sealant on my wood grain to help keep it clean and help against scratches.
Regards,
bump for exposure. Any restoration method? Does sanding refinishing work?
Why would anyone put "resin" on top of varnish? That doesn't make sense. The factory wheel is stained, then a layer of polyurethane mixed with stain is applied then a final layer of polyurethane. There are likely multiple steps of each.
