Need help removing Condensation/Water in the Headlight Assembly
My passenger side headlight assembly (both the main piece and smaller piece) have A LOT of water in them, it's fully covered with water droplets, not just fogging up, and recently the headlight stopped working. I brought it to an independent shop to get the headlight replaced and asked them to remove the water for me, and was told it's not possible without breaking the seal.
I did bring up the idea of using a blow dryer but was told that it's no possible on the 3GS, because the bulb itself is not actually in the headlight, it has a plastic cover/film in front of it. So the only way to get into the headlight is breaking the seal and getting the water out or getting a new headlight assembly. I do not want to open it up because it will possibly get dirt into it and sealing it may not be perfect either, which the condensation problem may come back.
So is it true that it can't be done with a blow dryer? My car is a 2007 GS450H which is out of warranty, should I bring the car in to a Lexus dealer which will cost $500+ to get it replaced or is there any possible way of fixing it?
I want to just live with it but its so damn ugly
Any input will be greatly appreciated!
Well if you bring it in to lexus they will charge you something, I had this issue but yours is serious. You could look on ebay or bring it to Lexus and see if they will goodwill the part and most likely they will make you pay for labor. Another choice is to stick it in an oven and break the seal that way and clean it out then re-seal it.
Thanks, I am planning on bringing the car in today and see what they say. Did they replaced it for you for free under or out of warantty? As long as it won't have any electrical problems or affect the light bulbs, I think I will live with it for now if they are going to charge me for the parts.
I just have a quick noob question, when you guys say serious, are you saying that it will lead to other problems? or just an ugly headlight with water in it? because the way I was told is that it won't affect anything else because this kind of headlight assembly is completely closed up. It's isolated from any electrical stuff.
I just got back from the Lexus dealer and was told that the water got into the electrical system and I have to get the whole headlight assembly replaced along with the some kind of electrical system behind it. And the cost will be around $2000 for the part and $300 for labour. I will probably have to get the bulbs replaced too... If not, I will have to drive with one headlight only cool....
Water got to the ballast and destroyed your ballast. Once the light starts doing it it collects a lot of water and it sits in the bottom of the light and that's where the ballast is.
Lexus already has my part on order, I'm not really a do it myself kinda guy, no idea what I am doing when it comes to anything under the hood. I'm not sure if I can cancel it since they special ordered it for me, I was also told that the water corroded all the wirings behind the headlight too hmmm... weird thing is that my other headlight also went out yesterday, turning it off and back on solved the problem, but unfortunately I was stopped by a cop because of it... I notice that it blinks a little when turned on, don't know if it's normal.
I'm paying it out of my pocket, they didn't seem to want to help cover some of it at all. They told me that it's either that I replace it or drive without that headlight. I guess it's fair as the car is out of warranty, there's no valid argument for me to bring up.
Update
Got the headlight replaced and they gave me a discount, I noticed that they put a few tiny scratches into the headlight when installing, not a big deal since it should come out when I use PlastX, I just need to restore the other headlight to make them look more identical.
I noticed that the right side shines a little further than left. I know it's adjustable but is it normal to have the right side shinning a little further on the 3GS? ( I heard in some cars they do it so its easier to see signs).
Update
430, assembly, condendation, condensation, es330, headlamp, headlight, headlights, lens, lexus, lexusmoisture, ls, putco, remove, water
