GS transmission problems?
#46
My transmission just went out at 103K miles. Its a 2006 GS. Received assistance of around 2K from Lexus. They paid for 50% of tranny and dealer took off labor. Total cost for tranny $2500. Also, engine had to be rebuilt by Lexus ad 83K miles. Out of warranty but Lexus covered it under goodwill.
#47
Nickeltime -
Since I'm in the same situation (with a few more miles), I got to ask - how did you get Lexus to do that? I've called their corporate US headquarters and I'm just getting the run-around.
Thanks.
Thanks.
#48
We bought this can pre owned certified. Lexus had all books and records. They told me that since it was pre owned certified, they took this into consideration when they made us the offer
#49
I'm at 115k no problems. Lexus did my trans fluid replacement also @ 90k.
I also have a friend with a 06' 300 and he's at 175-180k mi right now. ZERO problems on his car. He's only done the recalls on it and hasn't had oil consumption problems at all either. Previous owner (his brother in law) has taken great care of the car and babies the gas pedal (so do I).
If it's any consolation (like one of the posters above). My car is a garage queen, It literally stays in the garage ALL week. I drive it 2, sometimes 3 days a week if I want to take her out.
#50
Did he ever have the transmission fluid changed?
#51
So dropped off the GS to Cerritos Lexus today for the fuel recall. My SA said its a 50/50 on the transmission flush to fix the issue. Been driving the GS more often after the transmission wouldn't past 3rd but i haven't had any problem since.... took off my exhaust and intake and the car seems to run smoother..... but asked for the transmission flush and it will cost me about $260 and $89 for the rear diff fluid.,. debating on doing this.....
#52
#53
A few questions Goku, do you know if the GS350 and GS300 have the same tranny? I never got a reply and since you;re a moderator i thought u might know... Before the tranny fluid change have you noticed any vibrations, or slipping when shifting gears? What is your daily?
#54
So got my car back from the Fuel recall but my SA told me that P0761 Solenoid C and P2714 Pressure Control Solenoid. But advised to get a rebuilt tranny from Lexus for a long term fix. or a used one... But would hit the pocket about 5K.... has anyone else seen the P2714 code worth just getting the new solenoid or calling it a quits???
#55
EDIT: I hope this PDF link answers your questions. I looked it up on google right after I posted this: http://www.automaticchoice.es/Catalo...e/aw_a760e.pdf
#56
I'm pretty certain that since our transmissions are all 6-sp (GS300, GS350, & GS430) that we should have the same trans. As for vibrations and slipping when shifting gears, I noticed no such thing. I noticed the shifts were getting harder though, like I banged it into gear when I hit the throttle as soft as possible. After the fluid change the shifts were smoother a lot more. My GS is my daily. I just hitch rides wherever possible because I'm keeping this car for a long time and when I DO decide to get a new car it'll most likely be a newer GS (if I can hold out long enough, it'll be a used GS-F).
I would say look for a transmission ECU first. I remember a little while back one of our members had transmission problem. Bought a used but good working trans and it still had the same problems. He replaced the ECU and it worked just fine. Spent a ton of money to fix a few hundred dollar issue.
.. get to the office and Check engine and VSC pops on... just my luck...
#57
[QUOTE=XxGoKoUxX;9131771]I'm pretty certain that since our transmissions are all 6-sp (GS300, GS350, & GS430) that we should have the same trans. As for vibrations and slipping when shifting gears, I noticed no such thing. I noticed the shifts were getting harder though, like I banged it into gear when I hit the throttle as soft as possible. After the fluid change the shifts were smoother a lot more. My GS is my daily. I just hitch rides wherever possible because I'm keeping this car for a long time and when I DO decide to get a new car it'll most likely be a newer GS (if I can hold out long enough, it'll be a used GS-F).
Hopefully I can flush it as soon as possible. I Think maybe you're right the shifts are just hard and i feel a bit of vibration around 20-30mph as if it wants to shift. The funny thing is is that when I put it on ETC PWR mode it doesn't do any of those and the shifts become less violent... but the throttle feels so much better... Maybe its the fact that I drive it in manual mode but I dont really rev it out
#58
I have exactly the same transmission problem with my 2006 GS300 as peewhy. It will not go past 3rd - 130,000miles, no ATF change that I know of. Error codes P0761 and P2714. Works for a while after I disconnect the battery and shifts fine using manual changes. Haven't tried anything yet. Is it more than likely an ecu/wiring issue than a solenoid one since it works okay in manual mode and unlikely that both solenoids C and D are broken as the codes suggest?
#59
I have this issue, Error code P0761, only shifts from 1 to 3. So far I have removed transmission pan, cleaned & flushed, new filter, checked solenoid C to be ok. But issue still persists. 115K miles.
Anyone know the correction for this issue short of a new transmission?
