07 GS 350 water pump replacement
Old 12-08-11, 01:52 PM
tim07GS350
tim07GS350's Avatar
Default 07 GS 350 water pump replacement
Hello all!
My wife's GS350's water pump has given up the ghost. I have a replacement pump w/gasket and want to install this weekend.
Are there any pitfalls to this or is it straightforward? I have a lot of experience working on cars but hadn't had to mess with the Lexus until now.
What major components need to be removed to get to the pump? Radiator, fans, ???
Thanks for the help,
Tim
Old 12-08-11, 03:10 PM
TWong350
TWong350's Avatar
Here you go. Straight from TIS. Good luck. Post some pictures and create a DIY. All members would greatly appreciate it!
File Type: pdf
lttlLater (12-28-20)
Old 12-08-11, 03:26 PM
tim07GS350
tim07GS350's Avatar
Thanks for the info! Doesn't look to bad. I'll follow up with my results and tips.
Thanks,
Tim
Old 12-10-11, 03:35 PM
tim07GS350
tim07GS350's Avatar
I did the job today. It took me about 2 hours. Pretty straightforward. '
I tried to take some pics but forgot to put the CF card in the camera
I marked up the repair document. It is not necessary to do some of the items in the manual.
Unfortunately, while taking off the hose from the radiator I broke the plastic connection to the radiator. I can't believe these cars have plastic radiators! That is real crap.
Trying to fix it, if not will need to throw in a new rad.
Tim
File Type: pdf
Old 02-25-15, 12:08 PM
newellwalt
newellwalt's Avatar
Default 07 ES350 Lexus Water Pump Replacement
Does anyone have the process for replacing the water pump on a 07 ES 350 Lexus?
Old 02-25-15, 04:18 PM
burny
burny's Avatar
Tim
Tell you the truth, this is an easier job than replacing the Alternator
Old 02-28-15, 05:55 AM
sam12345
sam12345's Avatar
I believe all modern cars have plastic ends on their radiators you will need to go aftermarket if you want all steel
enshiu (04-19-19)
Old 07-24-15, 10:30 AM
okcity
okcity's Avatar
where did you buy a new water pump from? can you provide me with a part number?
thanks in advance
Old 07-24-15, 02:44 PM
burny
burny's Avatar
you can get the Aisin off Rockauto for under $100 and get thermostat too if I were you. check MyLparts.com if you want OEM
Old 07-24-15, 06:25 PM
pman6
pman6's Avatar
wow. this is a $1000 job at the stealer.
Old 07-25-15, 02:43 PM
Bavaria
Bavaria's Avatar
Dealer installed water pump, thermostat, belt tensioner pulley and belt cost approx. $870. Extended warranty took care of everything but the belt. Car had 72k miles at the time.
The following 2 users liked this post by Bavaria:
enshiu (04-16-19), VertexA (10-14-20)
Old 07-25-15, 04:15 PM
shwalker07
shwalker07's Avatar
Just in case anyone is looking for a DIY here is a great video.
<iframe width="560" height="315" src="https://www.youtube.com/embed/GNkqu9N_V7I" frameborder="0" allowfullscreen></iframe>
Old 07-27-15, 08:08 AM
ibidu1
ibidu1's Avatar
That aisin is actually a factory toyota part, aisin is owned by toyota
enshiu (04-16-19)
Old 07-27-15, 10:56 AM
burny
burny's Avatar
eggsactly sir
Old 07-27-15, 04:50 PM
pman6
pman6's Avatar
dude is goofy as hell haha
dude said lexus wanted $600 for the water pump alone.
Quick Reply: 07 GS 350 water pump replacement
