Old 12-16-14, 10:54 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
Light Bulb Size Diagram - 3GS
Old 12-13-12, 03:05 PM
  #31
SSAstro
SSAstro's Avatar
thanks for the info
Old 11-23-14, 07:29 AM
  #32
GS3FIFTYY
GS3FIFTYY's Avatar
when you say tail light bulb size and stop light bulb size---LED. are you saying that the gs350 comes with oem led brake/tail lights? i engaged the brakes at night and they dont seem to be LED bright....
Old 03-06-15, 06:37 PM
  #33
flashes23
flashes23's Avatar
Which bulbs would I need for the lights above your head that turn on when the mirror is open? Also which light bulb for the trunk?
Old 04-25-15, 02:05 PM
  #34
burny
burny's Avatar
That chart just says LED for the Brake light and tail light bulbs. Not much help. Anyone know exactly which bulbs to buy for these? LED's come in different lengths so I need to know which LED to get for these.
Old 04-25-15, 10:54 PM
  #35
XxGoKoUxX
XxGoKoUxX's Avatar
Last I checked burny, the taillights and brake lights aren't changeable. I believe they're soldered onto a board.
Did yours burn out?
Old 04-26-15, 05:37 AM
  #36
burny
burny's Avatar
No, I am going to replace the trunk switch next week and was going ahead and replacing the bulbs while doing it. Guess I can do license plate light and backups. So when the tail lights and brake lights fail, you have to get an entire new board? Man that was a great design. Almost as great as this cheesy trunk switch cover.
Old 04-26-15, 12:20 PM
  #37
burny
burny's Avatar
By the way, I just replaced the mirror puddle lights with Sylvania premium white LED's. At autozone, a pair of the 194's is $13. Many of the instructions on here talk about popping the mirror out and so on and so forth. I took my plastic trim tool, looks like a putty knife and just popped the light housing out the bottom of the mirror and replaced the bulb. Both sides took under 10 minutes and adds a much needed update.
Old 04-26-15, 04:43 PM
  #38
XxGoKoUxX
XxGoKoUxX's Avatar
Mmmm, sounds like an easy job burny, thanks! I sure as heck need to change out some of these dimmed out leds lol
Old 07-26-15, 09:58 PM
  #39
pius222
pius222's Avatar
Default light bulb question
Dig an old thread out... What is the orange light slightly to the side of the main head light called? Mine is out on the passenger side. Thx.
Old 07-27-15, 10:31 AM
  #40
pius222
pius222's Avatar
Default found answer
Found answer here.
http:// https://www.clublexus.com/fo...-2008-3gs.html
Old 11-26-15, 08:40 PM
  #41
SK430
SK430's Avatar
Awesome thread. Just what I needed.
I am trying to replace DRL, parking, and fog light bulbs, can someone tell me if this would be correct:
2x 2825 (led blue/white) for parking light
2x 9005 for DRL light (default color)
2x 9006 for (led blue/white) for fog light
I just want to make sure this is correct and will work as the OEM bulbs have.
Old 02-18-16, 12:22 AM
  #42
Nick3gs
Nick3gs's Avatar
How do you replace the tail lights ?
Old 02-18-16, 04:33 AM
  #43
burny
burny's Avatar
I think they are panels
Old 02-18-16, 11:08 AM
  #44
frotiss
frotiss's Avatar
Hi does any one know how to change the License plate bulb Thanks
Old 07-14-19, 06:32 PM
  #45
Biglex978
Biglex978's Avatar
Hi guys I just bought a 2010 Lexus es how do I change my hids lights to led light ? What is the bulb size for the hid ? Do I need any kits or do I just order the led bulb and switch it out ?
Quick Reply: Light Bulb Size Diagram - 3GS
