Power Steering issue
Old 07-05-16, 03:16 AM
DVineRite
DVineRite's Avatar
Originally Posted by DVineRite
So today I am at/went to MY mechanics, and they helped out; we went the "harness/connector-route," cleaning the middle connector on the rack and the harness itself. They also notice corsion on the ground plate in the rack (close to the middle connector). They cleaned it off as well. I'm beginning to wonder if that was the culprit to the P/S light emitting suddenly also just in idle {coming on, then off again**. Overall I'm pleased wih help they did and and AWESOME information you guys have helped with this. I DEFINITELY going to be contributoring MORE to the forums in anyway I can. Thank you everybody. Let hope this helps remedy the issue until I can afford later to replace, if it actually will need replacing �� .
This is the ground they had cleaned to allow a better contact for the P/S. It was a bit corroded. The center connector they had cleaned is slightly to the left of the ground. Its easily accessible once you remove the plastic under guard.
itsmeyar
ES - 5th Gen (2007-2012)
06-26-16 01:20 AM
mandyfig
02-07-09 04:45 PM
PecosBill
Suspension and Brakes
02-06-09 08:42 PM
suprandsc
Performance & Maintenance
09-04-06 10:54 AM
additude
09-24-03 09:12 AM
Quick Reply: Power Steering issue
