New Lexus Owner.. New project..
Old 03-19-16, 12:19 AM
Ali2GS300
Ali2GS300's Avatar
Default New Lexus Owner.. New project..
Hello CL
Little Intro..
I'm a 25 years old middle eastern student in the U.S Taking Mechanical Engineering degree in Texas
Just bought a 1999 GS300 last week from Arizona with 1644XX miles on it.
Drove it back to Texas 500 Miles , 8 hours. no problems except the brake startes whining like a baby crtying and ABS and other ights on the dashboard.
Anyway, the main reason i bought it is to do an Aristo swap On it
maybe single turbo later.
The project:
I've done my homework .. well i tried to get all the infos i need to do the swap
Here are all the infos i found here and there
just need them corrected , if there is anything wrong. maybe i understood something wrong or got it from the wrong person.
1. Buy the car ( done )
2. Buy the aristo swap ( Done just waiting for it to get here )
3. 1998-2001 is the easier swap the harness is the same.
Originally Posted by 99 GS3
Use the JDM termination caps on the USDM body harness. It connects the pins in a different order if you look at the bottom of them you can see the difference. This is what takes care of the shiftlock. The threads you've prob seen where people had shiftlock issues or had to repin those body connectors did not get those terminators with their engineset.
to be hnest i didn't really understand it but i was going to look at them both when the engine gets here
4. the igniter is the same ( GTE vvt-i is the same like the GE vvt-i)
5. engine mounts are the same so it's a direct fit no need to buy or make any brackets.
6. not sure about this one i read different opinions about it. the drive shaft is not the same so i need to buy the gs400 one? or the Aristo one? or the SC400 one? ( I'm going to use the auto aristo transmission A340E )
The GS400 driveshaft does not work, you have to have the front half of the aristo shaft. It is the only bolt-in solution. It's cheap and easy enough to have a complete shaft made or have the gs one modified if it was not included with the swap
Yeah I do believe it is a direct fit for the SC swap.
7. Need to get the GTE fuel pump.
8. traction not gonna work.
9. of course add intercooler.
10. Heater hose nipple thing need to be cut or bend ?
You just gotta bend that heater core nipple to clear the rear turbo housing if your staying twins.
Let me give you one piece of advice that is worth contemplating. I recommend to bend the nipple and install the heater hose and clamp on that nipple before you put the engine in. You can do it alot more carefully and cleanly before the motor goes in.
The engine will touch the nipple as is when you set the engine in. But to bend that soft nipple without kinking it, and then getting the hose it and then getting the clamp on good is a huge pain once the turbo is up on it.
Am i on the right track
Last thing is Engkish is a second languge pls don't start flaming if i wrote somthing wrong LOL
I'll start updating when i start the work on the first week of April
Old 03-19-16, 06:44 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Welcome to the forums
Old 03-20-16, 11:13 AM
Ali2GS300
Ali2GS300's Avatar
Thank you
Old 03-21-16, 07:27 AM
sade04
sade04's Avatar
Nice car! Looks like you're already well on your way. Where in the middle east if you don't mind me asking? I spent a few years in Bahrain as a kid.
Old 03-21-16, 08:06 AM
sakataj
sakataj's Avatar
https://www.clublexus.com/forums/gs-...red-gs300.html
Old 03-21-16, 10:42 AM
Ali2GS300
Ali2GS300's Avatar
wow this is great !! Thanks
Old 03-21-16, 10:43 AM
Ali2GS300
Ali2GS300's Avatar
Thanks
yeah i live like 30 minutes from there
Old 03-21-16, 12:32 PM
wbmx1981
wbmx1981's Avatar
Smile
Welcome to the board and to Texas!
Old 03-21-16, 03:39 PM
nyc80rick
nyc80rick's Avatar
Welcome good luck with your project . Wow this is my twin when I was stock.
Old 03-21-16, 11:23 PM
Mcon
Mcon's Avatar
Welcome to the club and forum and keep us informed in your progress with your swap.
Old 03-22-16, 12:16 AM
Ali2GS300
Ali2GS300's Avatar
Thank you guys.. i will start posting everything starting the first week of April.
Firstang01
GS - 1st Gen (1993-1997)
03-05-19 04:53 AM
Spoolx
10-21-18 04:03 PM
1776dmc
02-15-18 04:51 PM
876
10-23-16 08:10 PM
japspec
07-30-09 02:17 PM
Quick Reply: New Lexus Owner.. New project..
