Getting lowered car in spec? (camber)
Hey guys, long time viewer of the forums but a first time poster so here we go:
Ive got a 99 gs400 and I am really tempted to get some tein flex z coilovers. I see the front upper mounts that come with the flex's seem to have camber adjustment, so thats great. The thing is, I am not sure what to do with the rear. I have heard of people just getting a new camber bolt and being able to get everything in spec. I know camber isn't as bad as toe, but I don't see many people saying you need adjustable toe when lowering because factory suspension should be enough adjustment. I wanted to lower the car to about a 1-2 finger gap (i have factory chrome 17's) because the car sits pretty damn high. So thats about a 2in drop if that helps at all. If you guys know what kind of bolt I could get that would be great, I don't want to spend a ton on new control arms if I don't need to.
Honestly if you're on the factory wheels, which are a 16" I believe, and only dropping a few inches, you should be able to get back in spec with the factory control arms and toe links.
OP: They make adjustable upper rear control arms as well:
And camber bolts kits are all over ebay:
http://www.ebay.com/itm/New-Pair-Lef...FUhgBZ&vxp=mtr
There is no such thing as front upper camber mounts for our cars.. our cars have double wishbone suspension up front.. so you need adjustable control arms to adjust camber..
Im currently slammed and with stock adjustments I was able to get 3 degrees camber all around..with 1-2 finger gap you should be able to get 2 or 2.5 degrees camber which is close to oem spec.
The tein flex's upper mount (tophat, whichever you choose to call them) has camber adjustment. But you're saying that those are kinda pointless to have because our cars wont be able to take advantage of it?
I have a 1 finger gap on Megan Coilovers... I had the alignment maxed out with the stock suspension components and absolutely destroyed a set of tires in less than 5000 miles.
I needed SPC adjustable upper control arms in the front and camber kit in the rear. Now everything is in spec and the tires are wearing perfectly.
Sweet. I just wasn't sure if i would only need the bolt or if id have to get the upper control arms as well.
Now look at this picture:
they will look like this...
http://www.inspire-usa.com/assets/im...eet%20Flex.jpg
Gonna need this thread really soon!
Subscribing
Subscribing
Scorchez (02-11-24)
I have the Eibach Pro Kit 1'' front 1'' rear drop w/KYB Excel-G's on 18'' 235/40/18 and I'm experiencing front inner tire wear especially on one side. They aligned it as close as they could but the front camber is still out of spec. Not really seeing any inner wear when I run my 16'' stock wheels & tires 225/55/16 or my 16'' snow tires 215/60/16. So I guess I need to order the SPC front upper control arms w/adjustable ball joints? Although I've heard people with a similar set up saying you don't need a camber kit with a 1'' drop and that the car should be able to be aligned with the factory adjustments? Also are the SPC arms good quality?
