Rear Squeaking sounds
Sorry this topic might have already been brought up before but my car is making some squeaking noises in the rear and I have tried everything to debunk it but I can't find the solution. When I'm cruising on the streets I also hear it from other fellow GS cars. It sounds like a bed spring sound. Thanks in advance guys
Check the headlight adjusting sensor. It has a small link connected to the left rear trailing arm (I think). Looks sort of like a sway bar end link but connects to a sensor that determines how much the suspension is traveling. Unbolt it and grease it up really good. Solved my squeak issue.
I would have someone bounce the car while you try and find the source of the problem from underneath. That's how I figured out it was my headlight adjusting sensor.
