98 GS4: car doesn't know door is open. Door Sensor Switch?
Old 11-24-14, 11:56 AM
GRANYZ400
GRANYZ400's Avatar
Arrow 98 GS4: car doesn't know door is open. Door Sensor Switch?
Yes, I've searched. And what I typically come up with are all the threads on the Door Lock Actuators going bad which is not the issue I am dealing with here.
My issue is simple: when the door is open, the "car" still thinks it's closed.
What I am having a hard time with, since this vehicle does not appear to have a traditional "plunger" sensor, is what part contains the "door sensing switch" (<-- what I am calling it). Does anyone know?
Here's a picture from another thread of a door with the panel off. Can someone circle the part I should be looking at please?
Thanks so much!
Old 11-24-14, 12:47 PM
rgarjr
rgarjr's Avatar
Door open/close switch is part of the latching mechanism.
Attached Thumbnails 98 GS4: car doesn't know door is open. Door Sensor Switch?-106909d1182707489_door_lock_acutuators_diy_dsc05804_5d3ebc5167832a40f713f486c82d9500ce79cd37.jpg
Old 11-24-14, 05:34 PM
GRANYZ400
GRANYZ400's Avatar
Thanks a ton!
Old 11-24-14, 08:19 PM
NoUltimatu
NoUltimatu's Avatar
So what is the solution for your issue? (I've got the same)
Old 11-24-14, 09:04 PM
GRANYZ400
GRANYZ400's Avatar
I'll let you know for sure when I get around to the fix, but it sounds like replacement of the door latching mechanism. I'm hoping there's a way I can fix the existing one...maybe it's sticking? WD40?
I'll let you know.
Old 11-24-14, 09:31 PM
justim
justim's Avatar
Is it cold where you are? Water got into my switch and froze on my old ES300 . The car thought the door was open which drained my battery by the end of the work day.
Old 11-25-14, 09:36 AM
GRANYZ400
GRANYZ400's Avatar
It is cold here, but nothing crazy (Seattle area). In my case I believe it's sticking. I sprayed it with WD40 and scrubbed it with a toothbrush really well (while installed on the vehicle). It is not back to normal, but it's better. This part is certainly the culprit - I am just not sure if I need to replace it or continue working the mechanism over.
I'll report back as I find out more.
Thanks
Old 11-25-14, 10:24 AM
KeyKeeper
KeyKeeper's Avatar
Old 11-25-14, 11:46 AM
GRANYZ400
GRANYZ400's Avatar
Thanks KeyKeeper. I wonder why the mechanism responded to a light cleaning? General rule is mechanical issue: intermittent failures/slow to respond. Elec issue: works or it doesn't.
I assume the detail part you marked on that photo is sensing a mechanical part's position. Maybe that explains why I made it better with cleaning? Hmmmm
Old 11-25-14, 12:17 PM
KeyKeeper
KeyKeeper's Avatar
The grease they use on these things turns uber sticky...more like an adhesive over time and especially in colder climates. Some WD40 or a good synthetic spray lube and maybe application of new grease will keep it working right. Theres a micro switch mounted inside the latch part that gets depressed by the latch "jaw" when you open the door.
Old 11-25-14, 07:20 PM
GRANYZ400
GRANYZ400's Avatar
Great info! Thanks again!
marty99
RX - 1st Gen (1999-2003)
12
09-22-22 05:03 PM
BinaryJay
05-24-20 07:31 PM
GCNTSi
13
02-24-19 09:30 PM
MrMark
07-02-15 03:37 PM
99rx
05-14-12 03:03 PM
Quick Reply: 98 GS4: car doesn't know door is open. Door Sensor Switch?
