Help with hoses on 2jz ge
I am just about finished with the timing belt, water pump, valve cover gaskets and plugs on my GS300. As you know, I had to take the throttle body and y-tube off for the valve cover gaskets. I thought I would remember but I am having a problem recalling how the hoses connect back to the y-tube. It's the ones going to and from the VSV between the y-tube and the firewall that I am having trouble with.
I tried following the vacuum guide under the hood but that doesn't help much. Does anyone have a few pics of what the finished set up looks like.
Here's a couple of pics of where I am now. The VSV is not shown in the pics. I know the smaller hose near the intake manifold goes to the underside of the y-tube. I know the smaller hose between the two fuel injectors also plugs in the y-tube. I know the larger hose under the VSV connector goes to the VSV and the PCV valve connects to the top of the y-tube. After that, I need help.
There should've been 2 brackets that held those lines and the connector . If you put the Y-Pipe back on you'll see the nipples where the lines connect there's no other places to put them so you'll be good. Since you took it off you already know how much of a ***** it is.
flash9
05-05-19 05:49 AM
