OEM vs aftermarket brake pads
Hey everybody, my brakes are getting to the point where they "grind" once in a while need to replace soon, lexus dealer wanted somewhere around 650$ just for the rear brakes which is ridiculous in my opinion. Can anyone answer would the lexus pads really be any better than the higher cost ones at say autozone? I'd much rather buy those and do it myself, also anything special with this car to look out for while doing brakes I would assume not but I'm still new to this car.
I personally bought Genuine Toyota/Lexus pads for mine, but not for any reason in particular, I just prefer quality genuine parts wherever possible.
Only thing I'd say to look out for, take a photo or make notes on exactly how all the springs/clips go as they are a ***** to remember and if you lose/break any the pads will rattle, as mine are now after they sprung off (from incorrect fitment) whilst driving down the road and are gone for good.
New brake clip/pin fitting kit was $80 AUD from Lexus.
Other than that, just take all the usual/general precautions when working on any brake system, because if you stuff it up and then go for a test drive with no/faulty brakes it could end in diaster.
Good Luck
-Chris
Good Luck
-Chris
some days I wish this forum would put in the widget i see in other forums that does an auto-search based on the OP, and post best results at the bottom for the OP to look through....
just saying.
just saying.
Thanks for the input, I was actually looking at the thermoquiets as my choice, prolly will end up going with them, save me close to a grand on brakes compared to the dealership. -_- how they get away with that is beyond me
Actually just called my lexus dealership, front and rear pads were available for 79.99 each which I think is actually a little less than the thermoquiets at autozone, I was surprised.
The price you were quoted is highway robbery! If you have access to basic hand tools, jack, and jack stands, you can do it yourself, easily. Depending on your mileage, a "fit" kit is a worthwhile investment. It might seem extraneous on inspection, but it helps to eliminate noise based on the pads having play to move around and make noise, usually a popping/thunk sound.
I believe you can even get the fit kits now from aftermarket vendors. I suggest Rock Auto, or stock OEM.
You can replace your pads, fit kit, and turn the rotors for about $100. A lot cheaper than your quote.
Just my 2 cents, but the first post says "grinding" when hitting the brakes. Maybe the rotors are trashed is why the price is so high. Or maybe im way off. **eats popcorn**
Good Rule of Thumb
1. If you hit on brakes while driving and you feel the vibration in your seat/rear section, it's typically rear brakes or rotors going bad. Inspect
2. If you hit on brake while driving and you feel the vibration in your steering wheel, it's typically your front brakes. Inspect.
3. If you hit on brakes while driving and you feel the vibration/pulsing in the pedal, it's typically your front rotors. Inspect.
