Can someone please identify the parts in this rear suspension pic?
Old 01-27-13, 01:43 PM
BayAreaLex
BayAreaLex's Avatar
Default Can someone please identify the parts in this rear suspension pic?
Hi folks,
I was under the car replacing the rear sway bar bushings & end-links (never mind that rockauto sent me one correct end link and one incorrect end link, gawd damnit!) to cure a rear rattle over bumps.
I was giving everything back there a good shake while under the car and I noticed that the part labeled as "B" was pretty loose. It looks to have a swivel on either end. What is it called and are these known to wear out? Unfortunately there is nothing I can do to tighten the resistance on the swivel ends.
Part "B" looks to link Part "A" to the driver side lower control arm (the one that the lower shock attached to).
These parts are only on the driver side rear.
Can anyone identify both of them?
Thanks.
Luke
Old 01-27-13, 02:55 PM
FinLIFE
FinLIFE's Avatar
Part b is just the link for the height sensor and im guessing a is the height sensor since its attached to it
Old 01-27-13, 03:48 PM
ThomasGS4
ThomasGS4's Avatar
^ What he said. They're for your auto-leveling headlights.
Old 01-27-13, 04:03 PM
BCHDAZ
BCHDAZ's Avatar
^^^^^x3...
Old 01-27-13, 04:32 PM
BayAreaLex
BayAreaLex's Avatar
Height sensors? Headlights? No kidding!
Thanks guys! Wonder if that swivel connector piece is replaceable? Can't seem to find it on Sewell
Old 01-27-13, 05:02 PM
BCHDAZ
BCHDAZ's Avatar
http://lexus.sewellparts.com/oem-cat...S300-2000.html
no part # but "B" should not be able to move up and down on the bracket. (bottom of pic)
Old 01-27-13, 05:20 PM
BayAreaLex
BayAreaLex's Avatar
Thanks for the diagram. I notice that part "B" is not listed?
Old 01-27-13, 05:48 PM
1sWt2GS
1sWt2GS's Avatar
thats what he said look above
Old 01-27-13, 05:49 PM
BayAreaLex
BayAreaLex's Avatar
Yup, I know it.
My question is more of a "wonder why it's not listed" :-)
Old 01-27-13, 06:55 PM
BCHDAZ
BCHDAZ's Avatar
you will probably find they supply it as part of part #89408B, and expect the electronic component of it to fail well befor the link.....
Old 01-28-13, 05:57 AM
Chin
Former Sponsor
Chin's Avatar
Part b will be relatively loose. Both ends of part b are on swivel ends. Think of part b like you would think of hood struts.
JAB
RX - 1st Gen (1999-2003)
09-19-15 11:09 AM
robbyk
02-16-15 12:59 PM
nevernu
ES - 5th Gen (2007-2012)
12-09-14 03:30 PM
Zexnos
09-05-08 10:36 AM
Quick Reply: Can someone please identify the parts in this rear suspension pic?
