Bad smell from the air vents
Old 03-17-12, 06:29 PM
msarahalex
msarahalex's Avatar
Default Bad smell from the air vents
I have a 2001 gs 300. Off late when I turn on the ac a foul smell comes from the vents then goes away after awhile. Is there a solution to this problem, coz I am even embarrassed to give my friends a ride.
Old 03-17-12, 08:01 PM
99 GS3
99 GS3's Avatar
Have you changed the cabin filter yet?
Old 03-17-12, 08:21 PM
guod
guod's Avatar
Had the same problem with an LS430 I had. This product, Interdynamics - A/C System Deodorizer, seemed to help a great deal; http://www.oreillyauto.com/site/c/de...ord=deodorizer
You just spray it up into the A/C drain hose and it will slowly drain back out after a few minutes.
Old 03-17-12, 09:03 PM
msarahalex
msarahalex's Avatar
I did change the cabin filter, but no change was noticed
Old 03-18-12, 03:07 AM
ebxgsxr
ebxgsxr's Avatar
i've noticed that on my car & my wife's car. i changed the cabin filter on mine (have one for the LS, but haven't gotten around to it yet). i noticed a slight difference with mine, but i can still tell the odor is there. now sure what it is.
Old 03-18-12, 04:00 AM
FMLis300
FMLis300's Avatar
I read a little into this a while back but been procrastinating on doing it. Might be mold in the AC ducting. Spray Lysol into vents and run on high heat for a few minutes. If you have time and patience, undo parts and clean inside the ducts and the fan blades of the AC system.
Cool. Might have to try that out.
Old 03-18-12, 09:35 AM
Arcadian
Arcadian's Avatar
+1 change the cabin filtre. When I worked at GM, we had a GM branded a/c anti-fungal spray that is just about odorless and really powerful. Also, if possible, turn off your a/c a few minutes before you shut off the car and blow outside air on medium or high speed, this reduces the amount of moisture build up after the car is parked.
aachowhan
10-13-19 07:53 AM
RealMCR12
RC - 1st Gen (2015-present)
08-09-17 01:13 PM
LexusGuy91
04-12-15 05:37 AM
ColeTrickl
09-23-08 04:55 PM
Benjamin T
RX - 1st Gen (1999-2003)
03-07-06 09:32 PM
Quick Reply: Bad smell from the air vents
