VSC/ABS/VSC OFF lights are on
i tried reseting ECU that went well but did not clear the lights i tried reseting the yaw sensor but i ran into a problem all post with directions on reseting the yaw sensor through the DCL3 by jumping CG and TS does not work on my GS because the pin outs are different, any one know the correct way to reset the yaw sensor for a 01 gs 300?
thanks in advance
thanks in advance
no check engine light on< (I will still run diagnostic check) yeah i ran through the ABS wires (will check again) I'm checking all my possibilities i appreciate the response.
suspension work as done only because it was hit on the driver front every thing was replace with oem parts..
I got some Tien CST installed today and the same thing happened to my GS4. My mechanic will be checking the car's leveling and doule check the installation job as it may have knock something loose during the process. I'll update this post when I have more info.
I had tie rods and brakes put on my car yesterday. This problem came up after the front brakes were put on. The issue is a bad wheel speed sensor on the right wheel. Apparently, the sensor was damaged while the tie rod was being removed. The cost for the sensor is $183 from Carson Toyota, about $40 less than the suggested retail price. It is about a 30 minute install from what I understand. ABS braking is not working when these lights are on.
I don't know if this is helpful but this is the cause of my issue I am in the middle of resolving. Hope this helps.
