sunroof question
sunroof question
ok well it started my sunroof my sunroof would not always slide back, but now its stuck tilted up the driver side will try to close but the passenger doesnt move, do you think the motor could be burnt out or could it be something else? i would appreciate any help you guys could give me
Check to see if your drive rail is alligned. There should be 2 marks on the side of the track that are lined up. That will adjust the forward or rearward movement. Then there are trox screws on the side that adjust the up and down movement of the moon roof.
