Post your GS's 20" wheel offsets for comparison please
Old 03-25-08, 02:03 PM
jjbenzo
jjbenzo's Avatar
Default Post your GS's 20" wheel offsets for comparison please
I am having more difficulty than I expected in choosing the proper 20 inch wheel set-up for my GS430 that require no mods. I think it would be a good idea/beneficial for not just me but many other members as well if we could get everyone with 20" wheels on their second gen GS who did not have to roll the fenders/or do other mods to post the exact size front and back along with offset. The SC guys were doing this and I would like to see what exact dimensions people with 20's are running without modifications. Pictures would be great too!
Old 03-25-08, 02:16 PM
SorrGwa
SorrGwa's Avatar
20x8.5 +35
20x10 +43
no rolled fenders, slight lowering is ok
currently running rolled fenders, lowered more, 15mm spacer for the rear.
i started a thread like this over the weekend as well =/
Old 03-25-08, 02:20 PM
jjbenzo
jjbenzo's Avatar
I dont ever seem to find any real, solid information that have pics provided. This is such a big investment that I must be certain that the wheels will look right once on the car. Do you by chance have any pics of your set-up? Thanks.
Old 03-25-08, 03:35 PM
SoCalSC4
SoCalSC4's Avatar
Well, that depends on your definition of "looks right." To some of us more "aggressive" guys, the everyday 20x8.5 +35> and 20x10 +43> doesn't look particularly "right." But if you want a slam-dunk set-up this is a good range for you to be in.
You might want to pick a style you like first and see if it comes in the offset and width range you need. No point in falling in love with some type of wheel made (for example) a G35 coupe with offsets in the +22 range. Those could be made to work, but are not a bolt-on deal.
Old 03-25-08, 04:07 PM
4ntvings
4ntvings's Avatar
^agree with socal 100%.
determine the exact style you'd like for your car then go from there. and take your time, GL!
Old 03-25-08, 05:37 PM
GS FONZy
GS FONZy's Avatar
Not only offset, but tires and drop play a role in all of this too.
https://www.clublexus.com/forums/sho...d.php?t=344321
Old 03-25-08, 06:05 PM
jjbenzo
jjbenzo's Avatar
Well, I have decided that the only wheel I want for our GS430 are the Asanti AF135's. They are a custome 3 piece wheel, so I assume I can have any offset I want..for the most part. I will not be dropping the car and intend to keep it stock besides the wheels. I would love to see pics of a GS with 20x8.5 with a +38 offset in front and a 20x10 with a 40-42 offset in back. This is what I have been thinking off..but would like to physically see it first and know that I will not have fitment or rubbing issues.
Old 03-25-08, 06:47 PM
GS FONZy
GS FONZy's Avatar
20s no drop
Old 03-25-08, 07:18 PM
VNN326
VNN326's Avatar
o_o are you rolling the front and rears?!?! i was thinking about just hammering the fronts and rears because im not good at dremeling lol.
Old 03-25-08, 10:42 PM
SorrGwa
SorrGwa's Avatar
i had my rear fenders rolled flat professionally. took roughly 4hrs, but was well worth it.
i got my hands on a fender roller, and with the help of a heat gun, i tried to roll my fronts. haha, u can totally see it was done by an amatuer. the only issue was the fender roller couldnt know swing back past the caliper as the roller arm hit up against the caliper. so the small amount of fender that i could not roll, i just used a small hammer and the heat gun. it turned out ok i guess but either way, the car needs to go to the bodyshop to fix.
correction, my rear wheels are 20x10 +43. with the 15mm adapter/spacer, the offset is closer to +28
Old 03-26-08, 04:10 AM
Tim
Tim's Avatar
Default Wheels
20x8x5 38 offset front
20x10 42 offset rear
ltuned suspension with no rubbing issues but shaved fender anyways just in case.. Good luck
Attached Thumbnails Post your GS's 20" wheel offsets for comparison please-homework-011-small-.jpg
Old 02-11-14, 12:44 PM
czr73
czr73's Avatar
I believe a 20x8.5 / 20x10 setup with 245/30/20 in front and 285/25/20 in rear will work on my 2004 GS300. Please confirm, thanks.
Old 02-11-14, 12:49 PM
Sevenevez
Sevenevez's Avatar
i think a 285 is WAY too wide. but if you are not lowering it, which definitely isnt my style, you may clear. Yakuza may chime in as he knows his stuff on setting up a wheel to perfection. And most people with Perfect fitments hold the offset # dear to their heart to each his own.
Old 02-11-14, 01:11 PM
Kyle Harty
Kyle Harty's Avatar
Offset offset offset!!
Old 02-11-14, 02:31 PM
czr73
czr73's Avatar
I think imma do what Tim did and use the same setup:
Now for the question on the tires. Should I get 275/30 or what ?
Thanks gentlemen.
Quick Reply: Post your GS's 20" wheel offsets for comparison please
