Is there any difference in the HIDs and non-HIDs headlights?!
Old 11-17-06, 03:26 PM
mikevanle
mikevanle's Avatar
Default Is there any difference in the HIDs and non-HIDs headlights?!
My driver's side headlight has a little condensation on it. I'm thinking of just buying another used headlight and swapping it out.
My car has factory HIDs. Most of the ones I see specify "non-hid". Is the housing the same?
Basically, if I buy it, will it work on my car?
Old 11-17-06, 03:27 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
They are not the same
Old 11-17-06, 03:34 PM
mikevanle
mikevanle's Avatar
Yea I figured it might be different because the HID bulbs are diff than the 9006. Thanks Dave.
Old 11-17-06, 04:25 PM
gsCrazy
gsCrazy's Avatar
hey,
my headlights had condensation in them twice already and both times i just took out one of the bulbs on a dry night.
it'll dry up after one or two nights like this. you could even take out both of the bulbs...
give it a try. if you do it soon enough it won't leave water marks inside.
Old 11-17-06, 04:42 PM
LexFather
Guest
Posts: n/a
Totally different. If you look at the Sewell GB, they are different part numbers.
Old 11-17-06, 06:05 PM
GSteg
GSteg's Avatar
It's not just the bulb mounts that are different. It's also the way the reflectors are designed. The HID-specific reflectors are designed to not glare when HID is used.
lexo101
03-16-21 04:14 AM
fastegg
05-28-15 11:28 AM
STREETGS
05-31-14 11:28 AM
gabelias
01-20-14 05:08 PM
Gordy35
05-20-08 07:25 PM
Quick Reply: Is there any difference in the HIDs and non-HIDs headlights?!
