Ground wire kit
Forum Administrator
This is probably as close as you're going to get.
https://www.clublexus.com/forums/sho...ght=ground+kit
here is the link the sun hyper grounding system install. grounding kits are not usually car specific. i set mine up the same way.
https://www.clublexus.com/forums/sho...d.php?t=161040
good luck.
good luck.
Well...that's pretty much what I've done so far. I am just not such a good mechanic and still can't locate ground points on my alternator and transmission.
Sure, I would like to see what's on your diagram. I think I found almost all the points, just can't locate one on the alternator and not sure if the one I found on transmission is the right one.
Here are the instruction for the Daizen grouding kit 1998-2005 GS40/430
Here are the lenths of the wires-
I don't kow the gauge of the wires but #2 & #8 are smaller than the rest. Maybe 4ga. & 6ga.
#2 & #8 are 6mm and the rest are 9mm.
I think the palcement of #2 & #3 should be switched from on the instructions.
#1- 29 1/2"
#2 - 47 1/2"
#3 - 28"
#4 - 62"
#5 - 10"
#6 - 25 1/2"
#7 - 20"
#8 - 34 1/2"
You can see largerpic's in my gallery
#1- 29 1/2"
#2 - 47 1/2"
#3 - 28"
#4 - 62"
#5 - 10"
#6 - 25 1/2"
#7 - 20"
#8 - 34 1/2"
