Messed up big time what do u think
I was underneath car checking oil pan gasket for leaks i look back and see a black rubber piece thats on trans i take it off realize its like a window to see the torque converter i think... i put the rubber peace back on started the car looking for oil leaks the ru bber piece gets snatched in the trans and i shut it off any help at all will be appreciated
That piece is made of plastic so more then likely the torque converter and flex plate probably chewed it up so it may not do any damage. Maybe you can turn the torque converter around and pick the pieces of plastic out. Was it making any noise?
You can get a USB Android endoscope camera and flexible claw finger pick-up tool for less than $30. Use the camera to find the pieces in the bell house and the claw finger tool to take them out.
Ok up date talked to Mechanic he basically said the same thing that it wont hurt nothing so i decided to start it up and let it run so far noise gone away and seems to be fine again thanks for all the help
