Electrical issues
Electrical issues
I tend to ramble so i'll try and keep this simple.
3 of my windows will not work at all. My drivers side is the only one that works. Also my radio and tilt wheel no longer work after discovering cut wires in the harness where they plug into the climate control and radio.
Will new door harnesses fix theses issues?
Also the regulators i purchased all work as i checked them before i installed them. I just have no power to them or the lock switches.
many things you can do to tackle this issue. these cars have to be reset to have all windows working again. do a search on resettting the windows by hold the window switch for ten seconds on all windows. my issue was initially this but then i found a "slamming the door" trick while holding the down button to start the reprogramming. sounds iffy i know but it worked on the first slam! haha i was shocked. then i found that my back two windows had bad wires in the door hinge so i jumpered them from the side panel to the switch. all is well now. I'm working on why my door locks won't work. i hear it wanting to work but nothing locks or unlocks. ummm GL TRVP
I forgot about the window lock button, I feel like an idiot, but i know now which windows work, only my left passenger door window is out of commission. I will be replacing that window today. i may just get 2 doors though because the door is a little trashy on the outside, and i need to get a passenger front door too. thanks for the help.
Dont want to start a new thread but is there a way to get into my trunk? The latch is broken and the key whole was destroyed so theres just a hole in it now? Do i have any other options to get it open?
u can take out that section and bridge the wires.....
what u can even do is get a lil push button switch and route the wires to it.......
this applies to the trunk lever and gas tank opener
01rxwhite
03-27-18 09:35 AM
