tail lights don't work Need the help of a gs300 owner
So got a ghetto gs300 and i can't get the tail lights to work, brake lights are good but tail lights don't work. Though here's the thing, the license plate lights are gone (including the plug/wire), the trunk light is gone, the fog lights are gone and the headlights were switched to HIDs and the radio is gone and amp/cd changer is unplugged. I wanted to know if anyone out there could unplug all that (or at least the trunk/plate stuff) and see if their tail lights still work before i go out buying new wiring and bulbs.
I tried a different Tail Light Lamp Failure Module(though not sure if that one was good or not since i bought it used, any way to test these?) but still can't get the tail lights to turn on
Check your fuses. Is there any warning lights on the instrument cluster? If this happen to me I would go ahead and replace all the taillights. If that doesn't fix it then at least you know all the bulbs are good. Just my 2¢.
no warning lights and all fuses good, replaced half the tail light bulbs with no luck so far
So I looked at the wiring diagram for the taillights and come to find out the tag lights and the taillights are in the same circuit. They have a common relay, fuse, and wiring. I also found out that the stop lights have a different circuit. That is why you have stops but no tails. I have my factory amp/CD changer unplugged. my headlights are HID's. My fog lights don't work, but everything in the rear works. I would try to fix the tag lights and their plugs/wires.
