Suspension Problems!!!!
Old 03-23-09, 06:26 PM
catano787
catano787's Avatar
Default Suspension Problems!!!!
My Lexus Gs 300 1993,Wobbles side to side on the rear at high Speeds on the Highway and everytime when i hit a bump or pothole??.I chaged the Struts It wasnt that,my other guess is balljoints Idk i nEED HELP THAT ****** IS ANOYING!!IS WORST NOW THAT I PUT MY 20S ON IT WASNT AS BAD WITH THE FACTORY WHEELS BUT IT STILL DID IT
Old 03-23-09, 07:11 PM
gs300cky
gs300cky's Avatar
did you check your ball joints yet?
Old 03-23-09, 07:17 PM
tim8oland
tim8oland's Avatar
mine is doing the same. how much is it to replace the balljoints?? where do i purchase these parts??
Old 03-23-09, 07:56 PM
catano787
catano787's Avatar
no i havent check the balljoints yet. but thats next some people are telling me it could be also the control arm so idk
Old 03-23-09, 08:52 PM
VIPdaily
VIPdaily's Avatar
could be balljoints, or just the control arm bushings..if you do change the balljoints out and plan on slamming the car, go with oem, i bought aftermarket ones and after a few months, they sheered right off
Old 03-23-09, 09:07 PM
catano787
catano787's Avatar
yea im planning on slamming it,how much does it cost to change the balljoints??
Old 03-23-09, 10:19 PM
VIPdaily
VIPdaily's Avatar
honestly, its super easy, if you got a huge breaker bar you can do it on the ground, just remember to load the suspension when you tighten the nut, but i did it on the ground in about 10 minutes eash side but i had my tools, on a lift with airtools you can do it in 5 minutes tops but cost depends, i think they are like a hundred bucks or so
Old 03-23-09, 10:57 PM
catano787
catano787's Avatar
ok where could i find the balljoints at a good price?and im also thiking on getting this
93-97 Lexus GS Adjustable Lowering Coilovers there on ebay tell me what you think?
Old 03-23-09, 11:29 PM
VIPdaily
VIPdaily's Avatar
i mean its up to you, i recomend oem ones, they seem to be alot stronger. as far as coilovers, which ones were you looking at?
Old 03-23-09, 11:38 PM
catano787
catano787's Avatar
ok for sure. i was looking at this for 100
http://cgi.ebay.com/93-97-Lexus-GS-A...3A1%7C294%3A50
Old 03-24-09, 02:36 AM
[ant]
[ant]'s Avatar
so it wobbles in the rear? with stockys and with 20s? have you had your bushes and things checked out? there isnt a problem with the swaybar is there, is it correctly mounted both sides?
id get a suspension place to have a good look around. did you get it aligned when you got the 20s put on? did they say anything?
Old 03-24-09, 06:26 AM
ranger2339
ranger2339's Avatar
Bushings bushings bushings.. Replace them.. Start with sway bar end links,check diff bushings,ball joints, any arm bushings etc. You cant lose if you start replacing them, it will make your car ride like new again.
Also I wonder how well those sleeve over coilovers would do on some KYB GR2s?
Josh
Old 03-24-09, 10:57 AM
catano787
catano787's Avatar
anyone know a good site to find those bushings and ball joints??
Old 03-24-09, 03:59 PM
ranger2339
ranger2339's Avatar
Carson Toyota is what I was told told. I think there a sponsor on here.
Maybe somebody else has more info for you.
Josh
Old 03-24-09, 04:11 PM
YupImJOee
YupImJOee's Avatar
those are a big no no. leave coil sleeves to hondas.
Quick Reply: Suspension Problems!!!!
