Hybrid Technology Unique topics related to the ES300h model hybrid drivetrain and other features/options found only on the ES300h. Please use the main 6ES forum for discussion about shared components with other sixth generation ES models.
Going straight without steering a 2013 ES300h?
Old 07-02-14, 07:50 PM
MY100thcar
MY100thcar's Avatar
Default Going straight without steering a 2013 ES300h?
I can't drive my 2013 ES300h straight (on a straight & level road) with out turning the steering wheel to the right, then to the left (over & over again) .
To be clear, I do not have to turn the wheel much at all but it has to be turned to keep it straight.
I had Lexus do a 4 wheel alignment yesterday and it did not help at all.
Is this normal ?
Does Anybody else have this problem ?
Thanks
Old 07-02-14, 08:14 PM
rustytank
rustytank's Avatar
not sure if i fully understand what you're saying but if you have to turn the steering wheel even just a little bit to keep the car straight, that's not normal.
Old 07-02-14, 08:53 PM
atoyota
atoyota's Avatar
I don't have any problems on straight, level roads. Roads with a grade or slight slope can cause cars to track off center some.
Old 07-04-14, 07:58 AM
don1
don1's Avatar
My 2014 ES 300h follows a straight line very well. Probably the best of cars I've had in recent history. Back in 1998 I had a Nissan Maxima which tended to wander but after checking the tire pressure and lowering it to the minimum acceptable pressure (maybe 32 psi) the problem was eliminated.
Old 07-04-14, 02:39 PM
MY100thcar
MY100thcar's Avatar
My tire pressure is 33psi in all 4 tires (cold before driving), that is the correct psi for this car.
It goes up to about 37psi after driving 5-10 mins.
I would lower it to 32psi if that would help, but I don't think 1lb.less would make a difference.
What is the cold psi in your 300h ?
Maybe 30psi would help keep it straight ?
I guess that would lower my MPG a very small amount, but that would be fine with me.
It may also help soften the ride. I find it does NOT ride as soft as my 2007 ES350 did. (I do NOT have the 18"tires)
Does anybody here with a ES300h ride with 30psi (cold) ?
Old 07-04-14, 06:16 PM
Dave Mac
Dave Mac's Avatar
I believe at 30 psi you would experience signigicant wear on the outer edges of your tires.
Have you talked to your dealer - you may have a bad tire(s).
You do have Michelins don't you?
Dave Mac
Old 07-05-14, 03:16 AM
don1
don1's Avatar
I too have my pressure set at 33 psi.
Old 07-05-14, 05:33 AM
mrBillFL
mrBillFL's Avatar
most cars are designed to track to the right, if you let your hands off the wheel... its a safety 'feature' for those that would fall asleep at the wheel.
have you done a 4 wheel alignment? what are the numbers?
note: the factory settings will usually specify some bias to the right, so your shop will need to dial that out. (go out side of recommended specs)
you would also need to verify the tires are balanced..
rotating tires could help.
-that said mine tracks straight.
Old 07-05-14, 06:24 AM
MY100thcar
MY100thcar's Avatar
It does Not track to the right. I just have to keep turning the steering wheel (a very small amount, about 1/4" - 1/2" each way) to keep it going straight
I had Lexus do a 4 wheel alignment last week and it did not help at all.
They were supposed to balance and rotate the wheels also BUT I don't think they did !!!
I marked the tires and the FRONT ones were NOT rotated !!!
They changed the REAR tires side to side. So much for trusting LEXUS
Old 07-06-14, 07:51 PM
mrBillFL
mrBillFL's Avatar
sounds like loose steering box. like a wandering or loose rack. -which would be a serious issue.
has a service adviser or tech taken it for a ride?
Lukas99GS
01-05-18 01:59 AM
Najeeh
09-30-15 11:11 AM
Rickyram56
ES - 6th Gen (2013-2018)
02-02-15 05:11 PM
IS_Sunny
Suspension and Brakes
09-07-07 11:55 AM
1niceride
Maintenance
09-27-01 09:58 PM
Quick Reply: Going straight without steering a 2013 ES300h?
