ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
How much did your water pump replacement cost?
Old 05-25-15, 07:11 AM
12jimmyjam
12jimmyjam's Avatar
Default How much did your water pump replacement cost?
I just picked up an 07 es350 with about 80k miles. As I commute roughly 40k a year, eventually it's going to be time to replace it. I remember they used to call for engine removal to replace it but apparently the service manual has been changed to where the simply jack up or lift the engine. Has anyone had theirs replaced since the change?
Old 05-25-15, 09:04 AM
nevernu
nevernu's Avatar
https://www.clublexus.com/forums/es3...terpump-3.html
see post 38
Old 05-27-15, 11:23 PM
ThumperPup
ThumperPup's Avatar
When mine went out on the 07 first dealer gave price of like 1400 dollars.
but then once they called the warranty company they only aproved like for 5 or 6 hours labor and the bump they paid all like 700 and i paid 100
it was crazy how the service contract company could get it done for around 800 at the same dealer that wanted me to pay them like 1400
Old 05-28-15, 08:08 AM
12jimmyjam
12jimmyjam's Avatar
I called my local toyota dealership and they said they could do it for about $600 (serpentine belt included) which was music to me ears. I'm glad to found an alternative route of replacing it without engine removal. With the amount of miles I drive it would have required saving a lot of money just for that service.
On another note, I do wish that the atf was easier to change!
Old 05-28-15, 10:35 AM
ESh
ESh's Avatar
I have no idea how to replace it without removing the engine, there's no place and I mean no place to work.
Old 05-30-15, 07:58 AM
Blueshark
Blueshark's Avatar
My mechanic told me the engine have be by lifted and bottom down to ease the replacement.
Old 05-30-15, 04:38 PM
ESh
ESh's Avatar
How many inches?
Old 05-30-15, 07:55 PM
Blueshark
Blueshark's Avatar
The job haven't been done yet in my case, so i don't know..
Old 05-30-15, 10:38 PM
NickTee
NickTee's Avatar
Instructions I found regarding the swap on a Sienna(same 2GR-FE engine).
OK, got it done. Here's the instructions. (Some of the wrench sizes may be wrong, but most are 12 or 14mm, some 10mm)
1. Jack up vehicle support front end with jack stands, or lift
1b. Drain coolant from radiator via draincock at bottom of radiator.
2. Remove front passenger wheel
3. Remove plastic inner wheel cover (2 bolts -10mm, 1 plastic push grommet)
4. Remove upper engine mount (two pieces several bolts 14mm - note where you took them out)
4b. Remove water inlet housing (hose on top side can be removed and bottom left on and whole thing twisted out of the way)
5. Remove serp belt (14mm wrench turn counterclockwise on tensioner pulley)
6. Remove both idler pulleys (14mm)
7. Remove pulley off tensioner pulley (TURN CLOCKWISE!) You need to remove this to access the bolts around the waterpump.
8. Remove waterpump pulley bolts (4 X 14mm) but leave the pulley dangling there unless you want to mess with jacking up the engine. I didn't. You will need some sort of either spanner wrench or screwdriver to hold pulley in place while loosening up bolts - mine weren't that tight.
9. Remove waterpump bolts - there are 16 of them. You don't really have to note where they are (except 2) because they are different sizes (14mm and 12mm). There are two that need locktite on them when installing later on. See below these will need to be cleaned with a wire wheel or replaced. I cleaned them with a wire wheel, they worked just fine this way.
10. Remove waterpump and pulley through the top of the engine. Don't forget to remove the old gasket too.
11. I cleaned both surfaces with brake cleaner as well as sanded both surfaces of waterpump and engine so that they were flush and no gasket material was left.
Install back in the same order. Torque on bolts is as follows:
Pulleys: 32 ftlbs
Waterpump: 14mm bolts - 15ftlbs (make sure there is no oil on these threads when installing)
12 mm bolts - 81INlbs/6.75ftlbs
2 bolts need loctite are the third bolt from the left on the top and bottom as you look at the waterpump on the engine.
Engine Mount Brackets: 40 ftlbs (horizontal bolts)/28ftlbs (vertical bolts)
Water housing: 7ftlbs
Check pages 773-776 of the 2GR-FE repair manual found in another link.
Hope this helps. It was pretty easy. Took me longer than it should have because I was figuring things out. Not all that difficult to do.
Old 06-12-15, 05:56 AM
dumbenhaue
dumbenhaue's Avatar
Mine went out right after the warranty was up. Cost me $1,243 for replacement, most of which was labor. They charged less than $200 for the pump.
Old 06-12-15, 03:06 PM
NickTee
NickTee's Avatar
And that's why I do the work myself.
Old 06-13-15, 07:35 PM
electdroid
electdroid's Avatar
Default Water pump replacement in Victoria
Metro Lexus in Victoria B.C. replaced my 2007 ES350 water pump at 115,000 km in August 2014. Total was $951 CDN for the pump, belt, coolant and labour and tax. The labour was $533, 4.1 hours at $130 per. They did not take the engine out and they probably did the job in 2 hours!
Old 08-24-15, 09:44 AM
selfserv
selfserv's Avatar
Default 2008 Lexus ES350
Pulleys: 32 ftlbs
I got upto 4b and struck there cuz the bolts can not be taken out of the aluminum lower engine mount(2nd one of the two) And this mount is in the way of water inlet housing. Are you suggesting you could get access to waterpump bolts by disconnecting the rubber hose to the water inlet housing(aluminum) without taking out the engine mount bracket?
Thanks
empinball
GX - 1st Gen (2004-2009)
07-22-11 08:46 AM
hlb
06-07-10 02:08 PM
bibber
04-22-10 12:11 PM
IS300_2nr
CL of Southern California
08-17-08 07:14 PM
wkinley@gm
07-17-07 05:09 PM
Quick Reply: How much did your water pump replacement cost?
