License Plate Bulb Removal
I don't have my owners manual and I've searched threads with no clear answer.
How do I change my license plate bulbs in a 2010 ES350? I bought some 194 JDM Astar LEDs. I took off liner and changed backup bulbs but can't figure out how to change license plate bulbs. I'd appreciate if someone took the time out to thoroughly explain. Thanks
If I recall, you just need to remove the felt backing off the trunk lid, and then remove a couple of bolts. The license plate bulb assembly then comes out fairly easily, I don't think you even need to remove the license plate frame panel.
But I don't think you can just change out the bulb because the light assembly is one piece.
Search for threads where people are trying to install a rear view camera.
https://www.clublexus.com/forums/lex...s-350-a-4.html
and,
https://www.clublexus.com/forums/es3...t-housing.html
and,
ekaiman341
11-04-12 06:44 PM
Slooooooow
07-29-06 04:03 PM
