ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
switch assembly
Old 05-24-13, 09:01 PM
fbrown159
fbrown159's Avatar
Default switch assembly
how to remove airbag from lexus 2009 es350 to replace switch assembly in streering wheel
Old 05-25-13, 05:38 AM
LexBob2
LexBob2's Avatar
That's best left to a dealership shop or other professional.
Old 05-25-13, 06:06 AM
SICK350
SICK350's Avatar
No it's super easy! You disconnect the battery first, then remove the two side clips in the steering wheel. There is 2 t30 torque screws you have to remove, then remove the air bag and remove the two clock spring clips on the back on the air bag. Then the two steering wheel controls pull straight off with a bit of force. There is a couple wire clips the plug into the wheel that have to be removed.
I've changed out my steering wheel to a Woodgrain wheel and installed new buttons as mine were wearing really bad. It took me about half a hour.
Good luck and feel free to pm me with any questions.
Old 05-25-13, 06:09 AM
SICK350
SICK350's Avatar
Here's a picture of one torque bit after the cover is removed
Old 05-25-13, 06:10 AM
SICK350
SICK350's Avatar
Here's the other torque bit on the opposite side
Old 05-25-13, 06:12 AM
SICK350
SICK350's Avatar
Here's a picture of the clock spring wiring, you pull up on the yellow clips to release from air bag
Old 05-25-13, 06:14 AM
SICK350
SICK350's Avatar
Here's a picture of the clips on the back of the steering wheel controls. You remove the one phillips screw then they just pop out, you have to pull them straight out with quite a bit of force.
zxfiles007
05-02-21 01:39 AM
khizr23
01-07-19 02:04 PM
Hiep25
06-03-18 02:18 PM
Mark
07-09-14 05:03 PM
MrBruin09
02-28-14 09:28 AM
Quick Reply: switch assembly
