ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
07 Es350 Fog light relay
Old 12-23-12, 09:22 PM
SICK350
SICK350's Avatar
Default 07 Es350 Fog light relay
Hello, I'm trying to find some information on a fog light relay for my 2007 ES350, I recently installed h.i.d's in the head lights high beams and fog lights. When I first tried out the lights everything worked but the fog lights, I started doing so trouble shooting and noticed my car doesn't have a fog light relay in the fuse panel. Can anyone tell me the number of the relay needed? And also if I plug in that relay will my fog lights work?
Thanks.
Old 12-23-12, 10:15 PM
nevernu
nevernu's Avatar
perhaps this is helpful. the fog light relay is in the instrument panel junction box (behind the coin box area)
File Type: pdf
Old 12-23-12, 10:37 PM
SICK350
SICK350's Avatar
Thanks for the reply! I'm actually looking for the number of the relay located in the fuse panel under the hood. The wiring diagram will be very useful tho as well.
Old 12-24-12, 07:09 AM
SICK350
SICK350's Avatar
I took some pictures of where the relay goes. There should be a forth big relay where my finder is. I hope someone has time to pop the hood and take a look for me it would be greatly appreciated.
Thanks again.
Old 12-24-12, 03:54 PM
nevernu
nevernu's Avatar
sewell parts has a full list of parts w pics
http://lexus.sewellparts.com/oem-cat...S350-2007.html
#1 PNC 85916D 9008087026 RELAY, FOG LAMP is the fog relay
you may find the part you are looking for somewhere in the electrical relay/fuses sections by looking at the pics in the engine compartment
Old 12-25-12, 06:28 AM
SICK350
SICK350's Avatar
Thumbs up
Thanks a lot, much appreciated!
Old 12-25-12, 07:34 AM
SICK350
SICK350's Avatar
Does anyone know if 85916D and 85916L are the same relays? Or is one for inside the car and is one for under the hood?
Thanks
Old 12-25-12, 06:00 PM
SICK350
SICK350's Avatar
Smile
So after much research I found out there is 2 fog light relays one behind the coin box area and one under the hood, there's also 2 fuses, fog rr under the hood and fog fr by the drivers feet fuse box. I'm not sure why but my car had 1 fuse and 1 relay both in the interior fuse boxes, the fuse and the relay under the hood were missing for some reason??? I've replaced the fuse under the hood and I'm going to order a new denso relay off of ebay, hopefully that fixes my little fog light problem.
Does anyone have any idea why that fuse and relay wouldn't be installed? I'm wondering if a garage that the previous owner had took the car to maybe had taken it??? No clue?
Thanks for all the help and drawings they were a big help!
I took a picture of the relays and fuses that are behind the dash, some interior pieces had to be carefully removed and installed.
Old 12-25-12, 06:02 PM
SICK350
SICK350's Avatar
Here's the picture, didn't work in last message.
Old 12-25-12, 06:47 PM
xanderES
xanderES's Avatar
My fog lights work fine and I am missing the fuses in the fusebox under the hood also.
Never been tampered with as I am the first/only owner. I'm not an expert in electrical and I have no idea how else to help but I thought that I would chime in.
Pretty sure its not the ones under the hood though...
Old 12-25-12, 09:06 PM
SICK350
SICK350's Avatar
Talking
I just noticed that the relay and the fuse under the hood are for a rear fog light used in some countries, my hid ballasts were wired opposite and the part the plugs into the 9006 port just needed to be flipped around and my fog lights are working again! The only down fall is I had to zip tie the plug as it doesn't clip in now that its reversed.
Thanks for your reply xanderES
patwaal
03-03-15 09:56 AM
rajan31
01-27-15 08:20 PM
khutch
SC- 1st Gen (1992-2000)
11-10-09 01:17 AM
calichris
04-18-08 06:13 PM
Baybarea
39
07-03-07 05:45 PM
Quick Reply: 07 Es350 Fog light relay
