ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
2007 ES 350 headlight problem
Old 01-04-17, 04:52 PM
  #46
LetsBFrank
LetsBFrank's Avatar
Cool Helps a ton!!!
[QUOTE=dreyfus;6707040]If you immediately turn your headlights off and back on does the passenger light come back on? If so, you have a bad bulb. It's easy to replace yourself. The part will set you back $240 though (OEM through the dealer).
Dreyfus, My drivers side lamp just went out on me and i'm really glad that i found this thread. The dealer wants 175 for a bulb, but i'll get two off amazon for $100 and replace them myself with your instructions Thanks a bunch, err $175 (a replacement bulb plus dealer labor cost above me doing it myself)
Old 07-02-19, 09:05 AM
  #47
jwhite125
jwhite125's Avatar
Thanks everyone for your comments about replacing the headlights. I read the thread and was able to replace my front passenger headlight on my ‘07 ES350 with 177k miles. The original headlight was a Harison Japan D4S 35W bulb (Toshiba brand) which I replaced with a Philips D4S 35W 4300k bulb that I purchased on Amazon for $45. I took it to a local mechanic and he changed the bulbs for me for $5. The dealer was asking $175 per bulb and another $80 for labor. I appreciate all of the insight and helpful information provided on this topic. Thanks again!
Old 07-10-19, 07:02 PM
  #48
Riick
Riick's Avatar
Lightbulb
Originally Posted by jwhite125
... I replaced with a Philips D4S 35W 4300k bulb that I purchased on Amazon for $45. I took it to a local mechanic and he changed the bulbs for me for $5. The dealer was asking $175 per bulb and another $80 for labor...!
Yes, there is a reason behind people calling dealers - "$tealers".
Example: I had a suspension repair on one car I owned, where the lowest price I found was around $1,200.
Bought the best quality parts on Rock Auto for $180 (low-end units were under $85), and an Independent installed for another $150.
One of the HIDs on my '07 ES350 went out in 2014, replaced both with Phillips bulbs from Amazon at $90/pair, no problems in the 5 years since then.
BTW... aftermarket ballasts (effectively, transformers) are available if *that* turns out to be the problem.
Currently (07/19) amazon offers a plug-n-play ballast together with the D4S bulb for about $51
LINK:
https://www.amazon.com/Yikesai-Headlight-Ballast-Venza-Replaces-85967-52020/dp/B07K3WTS3G/ref=sr_1_2?keywords=hid+ballast+2007+lexus+es350&qid=1562810227&replacementKeywords=hid+ballast&s=gateway&sr=8-2&vehicle=2007-75-2866------------&vehicleName=2007+Lexus+ES350 https://www.amazon.com/Yikesai-Headlight-Ballast-Venza-Replaces-85967-52020/dp/B07K3WTS3G/ref=sr_1_2?keywords=hid+ballast+2007+lexus+es350&qid=1562810227&replacementKeywords=hid+ballast&s=gateway&sr=8-2&vehicle=2007-75-2866------------&vehicleName=2007+Lexus+ES350
Old 11-09-22, 05:24 AM
  #49
Blkboy90
1st Gear
Blkboy90's Avatar
Thank you so much for this. YouTube videos have failed me miserably but this key detailed list was idiot proof. Thank you very much!
Shyguy122
10-27-17 07:26 AM
Jaybeck860
IS - 1st Gen (2001-2005)
01-27-14 11:08 PM
GaryP123
08-24-12 07:42 AM
LaosXpress
11-10-11 01:55 PM
mitar84
05-04-11 04:34 PM
Quick Reply: 2007 ES 350 headlight problem
