ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Trunk won't open!!
Old 04-24-14, 09:30 AM
divilish
divilish's Avatar
Default Trunk won't open!!
I have a 2007 ES350 and my trunk decided to stay shut today, right when I arrived at work with stuff in the trunk....
The keyfob doesn't work, the button on the trunk doesn't work and the button inside the car doesn't work.
There is no clicking sound, it doesn't seem to be moving the switch.
I can open the trunk using a long stick and pulling the emergency lever.
I have checked the valet and that is not the problem.
I have disconnected the battery multiple times. Apart from losing all my settings this did not help the trunk issue.
I pulled the fusebox and don't see a "trunk release" fuse. I see a fuel OPN but no trunk.....
My fuel door works fine.
I am going to check every fuse after I get off work, but I figured I would see if anyone has had this issue before?
Old 04-24-14, 10:47 AM
nevernu
nevernu's Avatar
here are a few svc manual pages which might help
if i had to guess id say your glovebox valet button is somehow stuck in valet posn
File Type: pdf
File Type: pdf
File Type: pdf
Old 04-25-14, 10:34 AM
SICK350
SICK350's Avatar
There is another manual trunk release pull at the top of the hole you put your skis and hockey stick thru. That's a bit easier then fishing for the emergency lever.
Schimmy
05-31-24 12:03 PM
jasperx
10-15-18 11:07 AM
HOLGER21
06-05-17 11:34 AM
rziez
09-09-13 05:14 PM
StlGasMan
08-23-13 01:05 PM
Quick Reply: Trunk won't open!!
