Please help !!!!!!!!
hi i come from hong kong
i have 1999years es300 mcv21
i have some problem
i bought the jic magic suspension
how long does it take to install rear suspension , the suspension hits the inner rim
my rear rim size is 7.5j et42 with 225 45 tire
i wonder if anyone tired installing this set of suspension ? how to get it done ?
what kind of offset for car fender for this car and what is the value of j?
thank you
i have some problem
thank you
225 series tires are too wide for the back of the ES with stock suspension setup.
You'll need to run spacers and roll your fenders to make sure the rims don't rub.
Nice car BTW
Nice car BTW
The 4ES and 5ES use a 17x7" rim.
Two things;
1. I LOVE your car. Seriously, what a beautiful example, that was my goal for mine, but I sold it...
2. I think the offset is killing you. The 7.5 et42 is tight, a 5mm spacer SHOULD do it.
I used to run 18x8 ET 40, with 225 and I had ~6-7mm of clearance between the tire and stock suspension.
My last set was 17x7 225/45 with ET 40 as well, and I had almost 1cm of clearance.
Do you have another set of rims you can borrow, or try? There's no point to buy new tires if its the wheels that are the problem.
Maybe it is the wheels? Maybe the offset is higher than what you wrote? I'm having a hard time seeing an ET42 not clear. It SHOULD...
Two things;
I use the 10mm spacer now
But the suspenion hit the rims
I watch the offset chat for this car
http://cars-japan.net/wheel/n001104216.html
I should use 17 7.5j et30 rims ,right?
PhilipMSPT
06-05-10 03:26 PM
