ATF Leak
ATF Leak
Can't determine where this leak is coming from. You can see the drip in the picture where the reddish liquid is. It seems to be next to the pan but I'm not sure what part this would be. It's a slow drip but accumulates over time. Would appreciate some insight! Thanks in advance.
http://i58.tinypic.com/kd66vm.jpg
What's the fluid levels like?
Also check the power steering fluid - it also uses ATF.
That area between the transmission and engine is where the rear main seal is, but a leaking RMS would be engine oil, not tranny fluid.
ExpoGeorgi
03-05-13 07:43 PM
