battery cable loose at post 01 ES 300
Old 04-23-14, 01:56 PM
pauloil
pauloil's Avatar
Default battery cable loose at post 01 ES 300
cables are loose and it seems like the nut up front is tightened all the way. Is there a way to make it tighter by screwing down on the nut in the back, or do I have to put a new terminal on the wire end?
Old 04-23-14, 02:14 PM
PFB
PFB's Avatar
I had the same problem several years ago. It's prety common. The only Proper fix is to get new terminals from Lexus. Less than $20.00 each and very easy to replace.
Old 04-23-14, 03:12 PM
pauloil
pauloil's Avatar
do you just pry the cable out of the old terminal?
Old 04-23-14, 04:16 PM
PFB
PFB's Avatar
They're held in by a bolt. So yu need to unbolt it first.
Assuming its the originals, than it's very obvious when you look at them. It literarily took me 5 minutes to change.
Chelly
04-13-18 07:13 AM
mcclendon
05-11-13 06:29 AM
atdprod
08-09-10 12:42 PM
sexilexi
09-13-05 06:59 AM
Quick Reply: battery cable loose at post 01 ES 300
