Timing belt kit purchase.
Hello, I am going to do a complete timing belt replacement (seals, water pump, etc.) and I am curious where is the best place to buy the complete kit. I see Rocky sells the Aisin kit but some OEM kits are available on Flea Bay....... Where did you buy your complete kit?
I am a Dodge Charger guy who inherited this 97 ES300 with 225k miles fair condition so I want to fix it up as my winter beater so I want to keep the project on a low "affordable" budget. The AC compressor is shot and I don't want to spend the money on that....... Yet.
Thanks in advance for any suggestions.
Buy the Aisin kit with a water pump from RockAuto. Look for a 5% discount on Google, they always have a new code.
I believe the only other thing you'll need is two camshaft seals and an oil pump seal - they are notorious for leaking. I would get those from Sewell Lexus or any other Lexus/Toyota parts dealer. They make the best seals.
Other than that, I'm not sure if a new hydraulic tensioner is part of the kit. Welcome to the Club!
^you can get a kit with or without the Hydraulic tensioner. There's two versions.
And Rockauto is cheaper than the ebay sellers, even if you combine all the belts & extras they sell you as part of the kit, on rockauto.
That's where I get all my stuff, less some gaskets & fluids - those are dealer only for me, all else aftermarket !
hey all, i also like to use rockauto for parts and as a resource to compare prices for parts from other vendors.
<>why is the AISIN kit recommended above vs. any of the other kits rockauto has?<>
i am just curious, because I intend to order a kit and was considering the gates kit for $50 cheaper (both kits w/ hydraulic tensioner), aisin is better?
timing seal kit to add to timing belt kit purchase from rockauto~~Dayco part#SK0008 $9.83
http://www.rockauto.com/catalog/x,ca...parttype,11949
timing belt and water pump kit from Sewell~~$431.64
http://lexus.sewellparts.com/accesso...1998/3423.html
heads up, this kit includes a new thermostat as well, so seems a new thermostat is recommended when doing timing belt service
DON'T get the Gates kit. I got that for my ES330. The pump casting quality wasn't as good as the Aisin, I just I hope it lasts. The included construction-paper gasket is a joke, I spent $14 to get an OEM one at the dealer that I should have gotten with the Aisin pump.
A thermostat is only recommended because your coolant would have been drained for the waterpump job anyways. The thermostat is actually on the other side of the engine near the air-box housing.
