Damaged rubber bush, how would it affect my car?
Old 04-10-14, 09:59 AM
Aman
Aman's Avatar
Default Damaged rubber bush, how would it affect my car?
Hello Everyone.
Lately, I have been feeling as if there is some suspended weight in my car's front part as I drive over bumps; it often shakes like it never did before.
I have found a damaged rubber bush on a bar that holds some part of the engine but I am not really sure if this is causing the problem.
Can you please have a look at the picture, I need to know how it would affect the driving experience and should I keep on driving or it's dangerous in some way?
Thank you very much for your time and help.
Old 04-16-14, 11:32 AM
IzzyB
IzzyB's Avatar
That's a motor mount. Not a good idea to drive with it broken. If you're handy should be a quick fix. Just a couple of bolts I believe. Check around here and ToyotaNation for a DIY.
Old 04-16-14, 01:26 PM
ballsey
ballsey's Avatar
I had the same thing happen to mine, except all the rubber actually shattered and felt out. Not great to drive around on forever, however if you need to your engine won't fall out haha. I think a new one can be had for about $60 on Sewell
Old 04-16-14, 03:55 PM
mitmaks
mitmaks's Avatar
I would check out other ones as well, front one rear one as they might be in bad shape as well. How many miles on the car? http://www.ebay.com/itm/Engine-Motor-Transmission-Mount-Set-Kit-for-94-96-Camry-ES300-V6-3-0L-AT-Auto-/350891506833?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AES300&hash=item51b2c37c91&vxp=mtr
Old 04-16-14, 06:08 PM
Jaden1
Jaden1's Avatar
That mount doesn't look too bad. I doubt that's your problem. I'm guessing strut mounts or maybe control arms.
Old 04-16-14, 07:58 PM
mitmaks
mitmaks's Avatar
Watch this video, you might have same issue-----broken engine mounts
EmpPenguin
30
04-29-19 01:11 PM
Aman
04-16-14 11:19 AM
JPS
Performance & Maintenance
03-05-14 08:19 AM
LexiiBabe
01-13-14 07:50 PM
Carbon~IS
06-07-08 06:14 PM
Quick Reply: Damaged rubber bush, how would it affect my car?
