Gasoline leakage Don't know what to do.
Old 01-06-14, 02:45 PM
LexiiBabe
LexiiBabe's Avatar
Default Gasoline leakage Don't know what to do.
Recently my Lexi had been smelling like gas when I drive it. So I checked the hood and there's gasoline coming out of this thing on top of the engine. Don't know what to do I'm not really good with cars yet. Please help. How do I post a pic.
Old 01-06-14, 03:08 PM
LexiiBabe
LexiiBabe's Avatar
Well didn't see it before but ther is a screw on top of it. After screwing it in tighter it seemed to work but does somebody know what that part is called would like to search some info on it.
Old 01-06-14, 06:02 PM
Biddles
Biddles's Avatar
Go to Tinypic and upload an image, then post the one with [IMG] around it. Do not drive the car unless you are 100% you've fixed the issue.
Old 01-06-14, 09:10 PM
2jznosht
2jznosht's Avatar
Sc300 or 400? Where exactly is the piece located
Old 01-09-14, 01:45 PM
LexiiBabe
LexiiBabe's Avatar
Yea sorrg about the late reply ive been soo busy. . Yea its the black thing there in the pic and I have a 400. After tightening the screw it stop leaking but would like to know what that part is and how to prevent it again. Also is the engine ok with the gasoline that leaked on it. Thanks you guys.
Old 01-09-14, 03:13 PM
Ali SC3
Ali SC3's Avatar
the gas will evaporate in time, wipe down the excess if there is any.
what you don't want is there to be a small leak and start driving, once the motor gets hot it can catch on fire if there is still a leak.
that looks like the fuel pressure regulator, I don't recall a screw on them but I don't have a 400 to check, not sure what you tightened just make sure its not leaking anymore before you try and do anything else. did you tighten the bolts where it connects maybe?
Old 01-13-14, 07:50 PM
LexiiBabe
LexiiBabe's Avatar
Yea there was a little screw on top of the little black thing after I tighten a little bit the fuel stoped leaking out. I'm guessinng that the screw just came loose after all the years. My Lexi is about to hit 300 k in a little bit so I guess that's was the reason why. Hope it doenst happen again. Thanks again to all of your suppour my Sc brotherss.
EmpPenguin
30
04-29-19 01:11 PM
hsokhi
SC- 1st Gen (1992-2000)
32
12-23-14 12:41 PM
tuterz
07-15-13 05:16 AM
seankohl
08-03-12 01:17 PM
DosyBoy
05-31-12 02:39 PM
Quick Reply: Gasoline leakage Don't know what to do.
