Help Yet again (Trunk, Interior Lights.)
Old 04-01-14, 02:20 PM
xleoxx
xleoxx's Avatar
Default Help Yet again (Trunk, Interior Lights.)
Fixed!! It was the 7.5A Dome Fuse. Everythings running normally Again
_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=_=
I'm Having issues With my 1998 Lexus Es300.
Trunk Button Is not working it seems as if it isnt even sending signal back there.
FOB isn't working whatsoever.
Interior Lights are not working.
Dash lights work (I think) , Radio works, Headlights work, power locks work, Car starts and drives fine.
It was working fine a couple hours ago. I thought maybe the terminals so i cleaned them.
The switch in the glove compartment is unlocked but the trunk only opens if I open it with the Key.
Any tips would be helpful >.<
Update:The Ac Is only blowing hot air now. Added to the list of problems above.
Old 04-01-14, 02:32 PM
PFB
PFB's Avatar
The electrical wire going back to the trunk latch, sometimes breaks. It usually breaks where it runs along the trunk hinge. That's where it gets stressed each time you upen and close the trunk.
Old 04-01-14, 02:36 PM
xleoxx
xleoxx's Avatar
Would that have to do with the interior lighting too though?
Old 04-01-14, 03:51 PM
PuReChaos
PuReChaos's Avatar
interior lighting would most likely be a fuse, 7.5A Dome fuse,
The trunk, I would have to agree with PFB, unless your fuel door lid also doesn't work
Old 04-01-14, 04:01 PM
xleoxx
xleoxx's Avatar
You sir are correct I checked the lines that run up to the trunk and stuff everythings Fine I dont know How it slipped my mind to check the 7.5 dome >.< I just checked it And yea it's blown. Ty All For now my problem is solved!
Old 04-02-14, 05:58 PM
PuReChaos
PuReChaos's Avatar
Good to know it was something simple.
2ManyLexus
01-12-20 11:18 AM
jasperx
10-15-18 11:07 AM
HOLGER21
06-05-17 11:34 AM
divilish
ES - 5th Gen (2007-2012)
04-25-14 10:34 AM
00lexondub
03-17-05 11:40 PM
Quick Reply: Help Yet again (Trunk, Interior Lights.)
