Trick to Reinstall Air Filter 2001 ES300
Thank you for the posts about the air filter. I found them and removed the 2 behind the central instrument panel. I was able to reinstall the upper filter but I had problems with the lower one. One of my hands had to hold the gas pedal down and that left only 1 hand to install the filter. Because of the center plastic wall I couldn't see the slots to insert the filter.
In the end I couldn't install the lower filter. I'll try again later but figure brute force won't work.
Is there a trick to this?
VicSWFL
10-03-17 01:57 PM
