2000 ES300 AM/FM help
Old 06-23-13, 04:43 PM
flyfl1pguy
Registered User
flyfl1pguy's Avatar
Default 2000 ES300 AM/FM help
so now all Im getting is static. CD player and tape player works but no AM/FM radion station .
any ideas?-
Old 06-23-13, 04:50 PM
mdbrown
mdbrown's Avatar
Sounds like the antenna is unhooked, whether it's at the radio end or the window end (or inbetween) is the question.
Old 06-23-13, 06:19 PM
flyfl1pguy
Registered User
flyfl1pguy's Avatar
Thanks mdbrown!
Do you have any diagrams for the antenna to where they are located?
Old 06-23-13, 06:33 PM
mdbrown
mdbrown's Avatar
It's located in the rear window. Start with the easiest, check connection to the radio. If it's good there then check at the rear window, the connector is located behind the left rear C-pillar. If it's connected there then do a continuity check between the radio connection and the rear window connection.
Larry62
RX - 1st Gen (1999-2003)
02-03-12 03:28 PM
tidom78
01-15-07 09:42 AM
GRAND_LS 4
03-29-05 11:41 AM
skull791
05-16-03 07:08 AM
Quick Reply: 2000 ES300 AM/FM help
