a little confused
Old 05-11-13, 08:44 AM
BostonVP
BostonVP's Avatar
Default a little confused
How many vehicle speed sensor does a 1999 es300 have? I found one that located between the transmission and the air filter, but i see that some places are selling two different type of sensor. One is the black with one top screw (thats the one i found), and the second has 3 screw on it (which is the one i cant find nor thing mines has it) with an adapter of like 3-4 inches on the end.
Old 05-11-13, 09:20 AM
Received 3,049 Likes on 2,562 Posts
It has just the one (if you don't count the ABS wheel speed sensors). I see two different part numbers:
89413-08020 TOYOTA
89413-24010 AISIN - edit: this changes up to the above number so they are the same part.
Not sure what you are talking about on the sensor with the 3 screws, where did you see this? The first number seems to show up everywhere including Ebay and is used in many Toyota and Lexus models.
Old 05-11-13, 10:38 AM
BostonVP
BostonVP's Avatar
wassup man..this is the other one im talking about :
http://www.ebay.com/itm/Toyota-Vehicle-Speed-Sensor-VSS-Corolla-Camry-Celica-/320671233023?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1999%7CModel%3AES300&hash=item4aa97eb3ff&vxp=mtr
And about taht pulsation grinding noise that happen when i brake, well it was cause my 60 amp fuse wasnt working correctly. I ended up replacing cause it was broken from the tip, put a new one in and sazampp the pulsation stop when braking.
8052JZ
Performance & Maintenance
16
11-18-15 02:51 PM
Johnny D
GS - 1st Gen (1993-1997)
12-25-13 09:40 AM
Jerpam
08-17-13 08:58 PM
Mr Jokster
Suspension and Brakes
11-04-12 09:37 PM
Quick Reply: a little confused
