How to Install an Aftermarket Stereo/Headunit in a 93 Lexus ES300?
This is my first time install an aftermarket headunit.
I alrady purchase the PAC SOEM-4 Adapter and Metra 70-8112 Radio Wiring Harness.
I just want to make sure it before I do it.
I need connect the headunit power, Ground, and ANTENNAE to Metra 70-8112 Radio Wiring Harness; I also need connect the headunit speaker signal to input of PAC SOEM-4 Adapter then connect output of PAC SOEM-4 Adapter to Metra 70-8112 Radio Wiring Harness in order can use Factory Amp. without bypass factory Amp. and cut any wire? The Metra 70-8112 Radio Wiring Harness will connect to factory plug in order get the factory system work with aftermarket headunit right.
Please inform me above process is right.
Thanks
David
Thanks
David
rob97
07-11-14 05:29 PM
tsteele19
11-13-12 02:43 PM
redbarron
SC- 1st Gen (1992-2000)
06-18-11 08:23 AM
