1999 Es300 Tweeters
1999 Es300 Tweeters
My two front tweeters on my door in my Lexus es300 have finally gone after 14 years. I heard them starting to lose sound quality almost a year ago so I already knew what was coming. They still produce sound but it sounds like it is crackling because it is blown. I'm trying to find new tweeters for my car. What kind should I get and can someone send me a link with some photo's or maybe a video on how to get out the tweeters.
Thanks,
Shear
Thanks,
Shear
If you don't want to take a lot of trouble and time to fix them up, just get a used set on Ebay, they are pretty cheap over there.
They are easy to remove, open the door, grab the little plastic cover and yank it slightly up and away, it snaps right out. Once removed you'll see how it the tweeter bracket attaches, one 10mm bolt and it pulls out and then you can get to the connector to detach it.
Thanks very much,
Shear
Pulling up and away worked great for removing the tweeter cover. I needed to do this on my 1999 ES300 to reinstall the door panel. Door panel was off to fix a latch problem. The cover snapped back into place. Thanks for the instructions. Buckjeep
A heads up. The wire bundle between the driver's door and the body gets flexed the most, and broken or intermittant wires are common. Since the bundle is inside a rubber tube, you can't see the wires, and even if you could, a wire can be failing INSIDE its own insulation. The also applies to power door locks, window systems too. Often user manuals mention similar issues, but obscurely on some unrelated page...
Since the OEM tweeters and mounting are specific to the car, easiest is to get a used one off EBay and replace it. Going aftermarket opens up a whole can of worms: the door speakers are wired in parallel there is no x-over, so you probably want to get a set of component speakers for the door, and you gotta do a pair of them, both doors...next thing you know the whole car is apart and you are wiring a new stereo system...well that's how it would end with me anyways ;-)
