Sound when locking doors with remote
Old 09-06-12, 09:21 PM
kpierce
kpierce's Avatar
Default Sound when locking doors with remote
Hello,
I have an 2000 ES300, and a few things are starting to 'go out'. One of them is the beep noise when I lock my doors seems to becoming softer and softer. While the lock still works, I would like to keep thr beep noise as well. Any ideas what could be causing this?
Secondly, the middle console cup holder is jamming. If I slam the console cover hard enough thr cup holder will pop out. I have seen several post about different models, but nothing on how to fix a 2000 ES300, and hints?
Finally the control for my side mirrors has stopped working. I have checked the fuses, is there anything else other than replacing the switch?
Thanks for all the help.
Kip
Old 09-06-12, 09:58 PM
Hayk
Hayk's Avatar
Originally Posted by kpierce
Hello,
Kip
1. There is a volume **** underneath the dash (by your knees). It controls the beep sound.
2. The cupholders are known to break easily, I don't even use mine. Check to see if something is worn out or if there is an obstruction of some sort.
3. If the fuses are good, you have to remove the switch and check to see if it's getting power, with a multimeter.
Old 09-07-12, 07:28 PM
black01es
black01es's Avatar
Default Try this
Hello,
Kip
There is a volume **** straight behind steering wheel to adjust sound of beeper.
As far as the cup holder,it probley shouldnt be that to complex, but i guess it is, cause mine does it too.
Sorry bout your mirrors, no clue?
tofextras
07-10-16 07:21 PM
Power6
05-06-12 02:32 PM
hass
SC- 1st Gen (1992-2000)
09-07-06 01:01 PM
Quick Reply: Sound when locking doors with remote
