1992 lexus es300 wont start
Old 09-07-11, 01:09 AM
sadc
sadc's Avatar
Default 1992 lexus es300 wont start
So on my way to work, I slowed to into the main entrance of my working place(maybe 3-5MPH.) As I slowed down my car died. Tried to start it again, it never fired. Cranks but no start. So pushed it into a stall. I thought my fuel pump died since my car does have 219,xxx miles on it. So I sprayed starter fluid into the intake manifold through the throttle body. Still a no start. What could be the issue? About 3-4 days ago I cleaned my throttle body and my EGR(the one thats located next to the throttle body sensor) What else should I check for? I know I still have to check spark.
I also took out the AFM to see if it would start without it on but still would crank but no start. Im at a loss Thanks for reading
Specs on the car is:
1992 lexus es300
5 speed
spark plug changed 100 miles ago
Timing belt water pump pullys changed 200 miles ago
Throttle body, EGR cleaned 20 miles ago.
Old 09-07-11, 02:13 AM
sadc
sadc's Avatar
I also disconnected the battery and still a no start -_-
Old 09-07-11, 06:57 AM
mdbrown
mdbrown's Avatar
You need to check for codes and check for spark. Once you have that information you'll have a base from which to work. Otherwise you are just taking shots...
Old 09-07-11, 08:50 AM
EEngineer
EEngineer's Avatar
distributor rotor dead?
Old 09-07-11, 09:24 AM
1jizzle
1jizzle's Avatar
vtech lobes broken??
Old 09-07-11, 03:37 PM
sadc
sadc's Avatar
So I pulled a code and the only thing I was getting was code 24 Intake temperature sensor circuit fault...could this be the problem?
Old 09-07-11, 03:49 PM
mdbrown
mdbrown's Avatar
No, not likely. Have you checked for spark? It's very possible that you have a failing crank sensor, they don't always leave a code. Check for spark.
Old 09-07-11, 03:56 PM
BostonEs3
BostonEs3's Avatar
whens the last time you replaced the starter?
Old 09-07-11, 03:57 PM
sadc
sadc's Avatar
Sorry I also forgot to mention I check for spark with my voltmeter and I was getting above 1v
Old 09-07-11, 08:00 PM
sadc
sadc's Avatar
To my knowledge it has never been replaced but it doesn't sound like its on its last limb...
Tartar
11-10-18 02:27 PM
2mbee35
Performance & Maintenance
12-01-17 02:16 PM
Smitty1125
03-06-14 12:17 PM
Cashflo
35
05-23-11 06:02 AM
xsohaib
17
01-19-04 03:21 PM
Quick Reply: 1992 lexus es300 wont start
