Coolant drain and fill?
Old 04-24-11, 09:45 AM
  #46
GSteg
GSteg's Avatar
Originally Posted by yeldogt
Toyota still sells the old fluid -- my 05 says to only use the "super long life" ......so who knows. That TSB is from 2002? I have no idea what is up.
They tell you to use Super long life because they don't want you to change the service interval. The TSB is from 2002 because that's when the Pink coolant was introduced. They use the same TSB year after year until a new one comes out that says otherwise.
Toyota is great because they still sell red for guys like us who wants to mix our own and save some money. Honda did the same thing with their cars (phased out the old stuff for the new one around 2002 also). Except they don't supply the unmixed older coolant so you're forced to buy the new one which is fine since it works in the older systems too. It's just very expensive!
Old 04-24-11, 09:47 AM
  #47
GSteg
GSteg's Avatar
Originally Posted by schmoozer
I haven't put the car up on ramps yet, but I stuck my head under just for fun and couldn't find the radiator drain anywhere. It appears as if its protected by the skid plate down there..
Do I need to remove this?
Yes remove it so you can have access to it.
It should look very similar to this (different car):
Old 04-24-11, 09:54 AM
  #48
schmoozer
schmoozer's Avatar
Yea thats what it was like on all my former cars ^^
Heres whats in the FSM
It looks like I get to it from the front and a little higher up than the actual bottom. The FSM also doesn't mention removing the skid plate so I'm gonna cross my fingers when it cools down a bit outside.
Old 04-24-11, 10:08 AM
  #49
GSteg
GSteg's Avatar
The service manual are for techs so they aren't going to DIY every step. I've done radiator flush for 92-96 and 02-06 before and I've had to remove the bottom cover. I would be surprised if the 97-01 didn't require you to remove it. Good luck and let us know how it turns out
Old 07-15-11, 07:37 AM
  #50
enterconne
enterconne's Avatar
I can't find the rear drain plug....What's it by?
Old 08-05-11, 10:24 PM
  #51
Hayk
Hayk's Avatar
It's located next to the EGR tube and next to the Engine Plaque, right in between the exhaust pipes. The actual tap is behind the plaque and it's hard to attach a hose to it, but if you don't, all of your coolant will drain on the exhaust pipes. I managed to get mine on there. It's actually a miracle that I was able to find the rear drain **** - there is a slight clue in the FSM (it says that it's on the EGR cooler)
I'm going to take pictures and will make a separate thread for anyone who's going to attempt this.
Old 09-05-13, 12:37 PM
  #52
lifendet
lifendet's Avatar
Default bolt
Anyone know the part number for the rear plug for coolant flush on the back of the block..Mines stripped out and lexus parts department cant find it.They saying it comes with the block and not suppose to come out which I know is bs..
wbmx1981
Maintenance
11-09-22 12:23 PM
b2884987
RX - 1st Gen (1999-2003)
11-11-17 04:55 PM
apdxyk
01-28-16 04:13 PM
fade41
01-16-16 11:52 PM
saelee39
09-13-10 11:17 PM
Quick Reply: Coolant drain and fill?
