Alternator "whine" through stereo
Old 02-17-11, 09:42 PM
AndyG
AndyG's Avatar
Default Alternator "whine" through stereo
Just got an aftermarket stereo installed and I'm noticing some minor, but still annoying alternator whine coming through. Would grounding the entire vehicle/system better as mentioned in other threads be a good idea to help reduce this? Meaning the project where you ground the battery to the frame and other points around the engine bay also.
Any help would be great.
Old 02-18-11, 11:27 AM
ivory98es3
ivory98es3's Avatar
Did you just upgrade the HU? or did you upgrade the amp as well? If just the HU, did you bypass the stock amp or keep it. If you kept the stock amp and didn't bypass the stock amp, your solution is to get a couple of Ground Loop Isolators and install them between the HU and stock amp.
Old 02-18-11, 02:28 PM
AndyG
AndyG's Avatar
Cartoys installed it and they kept the factory amp so I will look into this Ground Loop Isolator you speak of.
Thank you!
Old 02-18-11, 04:20 PM
trickedout
trickedout's Avatar
Yeah, that sounds like the way to go, and if you got it installed by a shop then they most likely kept the stock amp installed.
Kane007
05-18-15 08:16 PM
KahnBB6
11-08-11 07:07 AM
richonenz
01-27-07 09:42 PM
Ag02M5
07-15-02 08:45 AM
Quick Reply: Alternator "whine" through stereo
