'95ES Warm Start Problem.. Sputters and dies
Old 11-24-10, 06:03 AM
immax01
immax01's Avatar
Default '95ES Warm Start Problem.. Sputters and dies
The car starts fine when it's cold, but if i try to start it within an hour of driving it, it sputters and dies unless i press on the gas for a few seconds.
It shows no other symptoms, it runs great. No rough idle. No CEL and no OBD codes.
I did a Google search but it seems that there isn't one single cause for this problem. I wanted to see if anyone here knows what this could be before i start replacing temp. sensors and the fuel pump.
Old 11-24-10, 07:49 AM
MikeLex
MikeLex's Avatar
It sounds like a leaking fuel pressure regulator.
Old 11-29-10, 06:20 PM
immax01
immax01's Avatar
So after some more research, I found that the ECT: Engine Coolant Temperature sensor could be acting up. I removed it and tested it for resistance (ohms) As instructed in the Camry repair manual. It gave me no reading, so i figured i will replace it. Then i gave the sensor a wipe down with some hot water, and suddenly i started getting a correct resistance reading.
Since then, I have had no problems. I'm not sure how a sensor can just be "cleaned", but it seems like that's what happened.
Old 11-29-10, 09:04 PM
WAES300
WAES300's Avatar
Definitely useful info. On my Pathfinder that I used to have, it acted up once with kind of a similar problem. I wiggled the MAF (mass airflow sensor) off a little, wiped down what I could, and put it back. What do ya know, it was back to normal.
JH48
05-24-19 05:32 AM
Benoit
IS - 1st Gen (2001-2005)
03-13-19 07:30 AM
Zmon
01-10-17 08:10 PM
jeffbarn
SC- 1st Gen (1992-2000)
06-27-11 09:34 PM
Quick Reply: '95ES Warm Start Problem.. Sputters and dies
